very strange with the low price and lack of information.....
a car this worked you must know kw ouput to ensure it dont blow up and kill everyone....
also why selling the car so soon? if its only done the one run y did u spend so much time and money to just sell it.....
interested....but a little sceptical.
https://www.sau.com.au/forums/topic/158440--/page/2/#findComment-3054485
Street tuned. Plenty are. I'm sure the owner will clarify. Looks like a fast car for the dollars.
https://www.sau.com.au/forums/topic/158440--/page/2/#findComment-3055124
the car made 350kw at the wheels no problem, if anyone was seriously interested they would have called! it isnt that hard!
anyway the car is NO LONGER FOR SALE...
it is in the shop getting a cage, chute, big arse turbo etc etc. will be running mid 9's very shortly
https://www.sau.com.au/forums/topic/158440--/page/2/#findComment-3072769
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
