Selling the following:
A Brand New Tube and Fin FMIC its a GTR one with excellent high flowing tapered end tanks for optimal flow. These are much better than the Cooling Pro and other cheap FMIC cores u see with their restrictive tiny end tanks with a inlet and outlet just suddenly plumbed in eg not tapered. FMIC is polised and looks shmick.
Dimensions:
Overall: 1000x300x78mm
Core: 600x300x78mm
3" Inlet and Outlet on end tanks
Pictures:
Price - $225 Final Price Drop now $160 Firm Pickup or will post interstate at your expense.
Phat 18" DTM Deep Dish Lightweight 5x114.3 mags with Bridgestone 540RE semi slicks fronts 90% / rears 20% tread these tyres are $450 each new! Rims are all 8.5" wide with +35 offset perfect numbers to fit Nissans. Tyres are 235/40/18 Front 265/35/18 Rears. Perfect for a drifter as u need exceptional front grip for precise control! - $1400 NOW $1000
ASE, AutoSport Engineering www.aseturbo.com BOV with original receipt for $320 different fittings are available from ASE for different sounds - $150ono
S13 Rear Camber Arms unknown brand silver/aluminium in colour but will adjust your camber no worries. Dial out some of that excessive rear camber u get on a S13 when u slam it or dial in some more to fit those dished 10" rims at the back!
Price - $100 Pickup
Location - Adelaide ready to be picked up and fitted this weekend!
Contact - Pm or sms 0404998591 (Can't answer mobile at work but can reply to sms and call back later)
Edited by nigelswazi
Whats the deal with those coolers, i see them advertised on ebay bolt into gtr but they clearly dont have enough monting points, when compared to say the chinese just jap one that has the 4 mounts?
i would be interested if it bolts in, not so much if it doesnt.
Hi mate,
You will find that the majority of aftermarket FMIC cores on the market actually only use two mounting points on the cars I have owned I have had a Greddy, Hybrid, HKS and all used just two mounting points on the sides. The two on the top sides of the intercooler are in the exact same position as on a GTR cooler which as u are pointing out a Nissan GTR cooler has two on the bottom two. Thats just overkill the two bolts at the top will be quite sufficient my mates GTR runs one of these FMIC's using the two mounting points with no problems movement etc. Its a straight bolt on.
FMIC now $160 FIRM pickup or plus postage
I see, where yours is dented if that a tube on top or that is just aluminum plate that serves no purpose other then to protect the cooling fins? Im interested to pick up...
Also the stock one has 2 pins there, how does this one fix to this spot? Is there holes tapped for bolts to go through?
Edited by GTR1993
