Ok my R34 MFD (multi function display) comes up with some writing in japanese and wont play anything but radio. I took it to my mate who can read japanese and he said i need a cd that resets the system.
Does anyone know where to get a cd to reset it? Is there a way of fixing this so I can listen to some tunes again?
Edited by pablo101
https://www.sau.com.au/forums/topic/158854-help-r34-mfd-needs-to-be-resetted/
try this - Disconnect the battery .. Leave it for 30 seconds and reconnect.. You have now reset the cd player ... however you will have to put in all new settings..
For the record only the r34 GTR comes with a CD player, The rest come with tape players, Series 2 might be different im not sure
  • 6 months later...
If you havnt already sorted this out, I found this on gtr.co.uk which should help.
This is the translation of pages 6&7 of the MFD2 manual....the directions will work with a factory MFD too.
Maybe Joss can put them up in the technical page...
From Page -6-
The car should first of all be parked on a flat area.
(1)Turn the ignition key to "ON"
(2)Push the Joystick once. Do not step on the accelerator.
If the GTR logo does not appear after step (1) & (2) follow these directions:
Turn the engine off by putting the ignition key to "OFF" Doh!!
Press "RETURN" & "MODE" together
When the GTR logo appears release "RETURN" &"MODE"
Press the joystick 5 times in 3 seconds
(3)When the Accelerator box appears (like in the pic to the left) press the joystick
(4)Work the accelerator to confirm the sensor works properly. When off it should read 0% and when fully depressed 100%.
(5)Turn the engine off by putting the ign key to "OFF"
From Page -7-
(1)Ignition to OFF....continuing from step 5 on the other page
(2)Turn ignition to ON while pushing the joystick
(3)Release the Joystick 1 second after the GTR logo appears
(4)Then quickly press the joystick 5 times in 3 seconds while the GTR logo is still being displayed
(5)The diagnostic screen should appear with all the different parameters listed.
At this point the shift up indicator (the "REV" light) should be on
The self test should be completed when all the parameter boxes are green. If the green is not displayed there is a problem so check connections and for short circuits. If INT TEMP or EXH-TEMP do not light up drive around for a few moments to get a positive reading.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
