  • Replies 490
Posted Images
Group Buy 24 order received...
- Slyne for R33 slotted rotors & pads (waiting for payment to clear)
- matteh33 for R33 front slotted rotors (payment cleared)
- falcs81 for R33 slotted rotors & pads (payment cleared)
- rinmak for R33 slotted rotors (payment cleared)
Group Buy 24 is now closed.
Will organise and submit these orders this weekend:
- Slyne for R33 slotted rotors & pads (no payment - cancelled)
Hey Mate
After rear rotors for early r32gtr (297)
Price for sloted delivered and dimpled delivered please
Also when would I expect to receive them?
Cheers,
Dave
Hi Albert,
Right now only rear 297mm R34 GTT rotors available, as this is interchangeable with R33 gts-t & R32 Gtst... (same part).
Front is not available yet, I've been chasing RDA on exact time when they'll be available but they still can't give me a sure answer yet.
But it's gone into production it's just probably they're still sorting out either QA/Testing/Importing/Shipping that causing the delay.
Hopefully we'll hear something by early 2008.
PMs replied...
As far as I know all R32 GTST have the same size front rotors 280mm.
The only one that is different is the R32 GTR V-Spec (93-94) which has brembo calipers and this uses 324mm rotors instead of the 296mm rotors in the 89-93 model with no brembos.
But if you want to fit the R33 GTST 296mm rotors at the front just let me know...
I'll be in for the last group buy this year.
I'm undecided on which rotors to go for though, can you pm me the delivered prices for both the slotted and the dimpled/slotted.
Front and rear for R33 Gtst.
Also, include the prices for Green and Red pads all round.
Cheers!
Group Buy 25 orders received:
- WORK32GTR for rear R32 GTR rotors
- CHUNDA for front R32 Gtst rotor
tuitahi, will send you a quote ASAP.
I will... just need a good break over christmas & new year...
No worries Rianto, it'll take my wallet until March to make a full recovery from the flogging it will get over the next couple of weeks ;)
- CHUNDA for front R32 Gtst rotors
- TURISMO for front R32 Gtst rotors
Group Buy closing by end of this week! Next one won't be till in 2008 so dont miss out!
PM received, updated Group Buy 25 orders received:
- bilbo117 for R33 gtst rotors & EBC greenpads
- intouch for R32 gtst rotors (TBC)
hey mate
Need a quote for front and rear rotors for R32 GTS-T coupe 90 model, wanting price for the slotted and none slotted, and do they come with pads give me quote with pads also.
thanks Bruno
PS send a Pm quick befor due date last order for this year
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
