Yeh thats right.
For that price it comes with 17inch blitz wheels, standard 4pot brakes and no cage.
There is lots of money spent on the car, so i'm not sure how much lower i have to go, but i am keen to sell so make an offer if you like.
Any test welcome.
cheers.
ahh ok so are they the rims that are on it at the moment?? im currently waiting on some money coming if it still for sale in 4 weeks u mite have a sale---maybe
this car definitely looks the goods, and price aint bad also
i'm actually after a gtr, but this one seems a little too hardcore for me, 300+kw geez.....wanting something a little more streetable !
Buddy Its Not like your going to be driving 300 Kws on the street you Can Always Drive the car on Standard Boost ? I personally think its good value Free bump...
good point, i'd still be a bit worried about the clutch on this though, racingline could you shed some light on how difficult it is to drive the with the button clutch ?
this car looks so god damn good, i'm so tempted
tarogo, The clutch is as easy to drive as a standard one. No shudder, hard pedal, etc etc. Its a cussion button, not a normal puck style unit that you would have heard were hard to drive.
Lexrex, Not at the moment, need the cash.
cheers.
I don't know what clutch this is, by my car has 300rwkw and i drive it everyday with a nice single plate clutch. Let my mate drive it the other day who hasn't driven manual in ages, he didn't bunny hope or stall it or anything once, he couldn't believe how easy/nice it was to drive.
if the clutch is as easy to drive as you guys have mentioned.... then i'm very interested!
do you have pics of the rims that will come with the car? and will there be any prob getting a rwc for this?
and you taking offers?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
