Ok this is like my 3rd neon post, and people are saying go for it and others are saying no, so just to get a general idea i started a poll
the neons will be RED as my car is white and the main feature are the red stove tops and the light on my wing
i want to put them under the door area and wire it to the cabin lighs!
Yes or No?
https://www.sau.com.au/forums/topic/15915-neons-or-no-neons/
for a white skyline, go for RED! but if u gonna rice your car up with red neons under your car, u should get red interior, red stickers etcetc...then it'll look damn rice! I mean nice :D
neons are good for car show and riced up, ..but it's your car and u do wat u want :)
https://www.sau.com.au/forums/topic/15915-neons-or-no-neons/#findComment-325430
Yeah and if i dont like it, or they draw too much attention or they look to ricey or a wank then i can just take them off :( and if it looks really good i can put a red cold cathode behind the word skyline in my boot :)
im geting the strong idea people think that its just Rice ;)
is it still rice even tho i am not driving with them on?
https://www.sau.com.au/forums/topic/15915-neons-or-no-neons/#findComment-325555
A5h, as you say it's your car & your decision.
However if you don't want to be instant cop-bait, then DON'T put those attention-grabbers on your car.
Let your car's innate style & class speak for itself.
You'll probably save yourself some unwanted hassles in the process.
https://www.sau.com.au/forums/topic/15915-neons-or-no-neons/#findComment-325970
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
