Hey there
Just sourced a R32GTR fuel pump for my R33GTST. Aiming for around 220-230rwkw so better to upgrade from the stocker.
The pump is supposedly only about 5-10,000kms old. This may or may not be true as I didn't see a receipt for it. I did ring Nissan and they just quoted me $880 for a new one, so the bloke that bought it new either shelled out a shtload or was telling porky pies or had a cheaper source than Nissan Sydney.
What I am wondering is if anyone has any idea on how long these pumps are good for? I know it comes down to a lot of variables..
It appears that the body of it is in very good condition and you can read the writing on it very easily. Is this a sign that the pump is farly new? Would a 15y.o. pump be visibly arnished by the petrol?
Will be installing it soon and will see how it goes but was keen to hear from others that have put R32GTR pumps on their R33GTST's
Thanks!!
Edited by benl1981
Installed an R32GTR standard fuel pump into an R32GTST in 1999 and it is still going strong (185,000 ks).
Installed a used R32GTR standard fuel pump into an R32GTR in 2000 and it is still going strong (80,000 ks).
Installed a used Z32 (same as R32GTR) fuel pump into an R32GTST race car in 2002 and it is still going strong. Now used as a lift pump.
Installed a used R32GTR standard fuel pump into an R33GTST in 2006 and it is still going strong (30,000 ks).
and a few more...........
:( cheers :laugh:
Thanks Sydneykid.
I was just concerned that I may blow the motor if the pump fails..
Hope for the best I guess. But if you have trusted them (even though they are old) I feel a little better :P
Cheers
Ben
Hi Ben, if the pump fails, the engine stops, no damage there. They usually start to make noises before they die completely. If you are using a standard computer, then the knock mapping will save your ass. If you are using a Power FC, the knock warning will flash on the dash. Not a lot of risk there.
:( cheers :laugh:
:laugh: cheers :)
So this should apply to any fuel pump? If so why do people keep banging on about risking your engine with Walboros?
i think the biggest risk is when the fuel pump cant keep up or progessively failing. if its just instantly custs out it should stall, but if its progressively flowing less and less you will lean out and then go bang.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
