Hi considering selling my hiflow turbo
i have since had it rebalanced and cleaned by turbo australia
recorded a 320rwhp on dyno
very minimal shaft play, but as i have been told plain bearing turbos require a ver minor of play for the oil to lubricate the wheels.
the play is still the same as it was from when it came back from turbo australia.
Very good condition turbo, no noises, no leaks, nothing wrong with it.
only reason for selling is saving up for a gt30r turbo.
any offers above $700
Edited by bazr33
im actually going to put the turbo on ebay, so it will be up in a couple of days
its only done about 3000kms
turbo australia had done the hiflow orginially, and i had it also cleaned rebalanced, changed bushes and 270 thrust bearing put in.
hmmm arent the turbos off skylines like no good after 14 psi ? or is it a myth ? id still be interested though id have to make a custom manifold to fit onto my SR. hmmm ill get back to u .,
yeah stock turbos with the ceramic compressor wheels arent much good after 14psi.
but this one has been hiflowed and has steel wheels, so it can handle more boost, max is about 18psi.
Also the wheels in this hiflow are bigger then a stock turbo.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
