high mount turbo rated 600 hp
exhaust manafoild
external wastegate
upgraded fuel bump
fmic
3in zorst
e boost 2 electronic boost controller
safc
would lik to no wats the best option on ecu is price not really a issue just want an idea. heard microtech pretty good. :P thanks
https://www.sau.com.au/forums/topic/159489-ok-these-r-my-mods-wat-ecu/
If you plan to tune it and leave it you can't go past Dr Drift stock ECU re-map. My car is re-mapped and I could not be happier. Very cost efficient. R32 $700. Silvia about $1000 that includes dyno time and tuning of course.
Note: can only be done to silvia's and R32.
If R33 need a power FC
I see you have R33..??
My pick is power FC, if unable to source one nowdays Haltech now make awesome plug in ECU's.
If budget and manhours are no object of course MOTEC is the only way to go.
motec is definately the best... microtec and wolf 3d arent so great.
motec doesnt use AFM though.
uses tps and map sensors i think, so there is a bit of work to get it going, but the most rewards in the long run
Not a fan of Microtec myself, and I ran a Wolf3D V4 in my rotary - wasn't impressed.
If you don't want to spend a fortune, I'd recommend going for an Apexi Power FC, however be quick as Apexi just went broke so they will probably be thin on the ground in no time.
power fc if you can get your hands on one... wouldnt the dr drift re-map with standard ecu not really be up to par with such a highly modified vehcle, big turbo external gate, big injectors.....the standard ecu's never meant for that, you wouldnt think a chip would help it out that much
  • 6 months later...
Mate, do your homework before you go giving advice. Dr Drift certainly do R33 ECU's... I just had mine done... $1200...
A mail order remap would probably not be ideal, but a factory ECU tuned in real time on the dyno with factory knock feedback is IMO by far a better option than PFC... Can easily take into consideration cams turbo injector and afm upgrades...
:) And how well is yours running for such little dyno time? It was around 1.5 hours all up yeah? When are we fitting the rest of the bits? I can't wait to 'advertise' the potential of the factory ecu on the 33's a little more...
We've nearly finished our own R33 build project, looking for 300+ rwkw daily driver on pump fuel, with stock ecu... just something interesting for the missus to do the shopping in :(
Nothing wrong with microtec unless you have a retard tuning it. the early model microtecs arnt the best i agree and they are very limited in features/inputs etc but if you have a great tuner like i do (UAS - free plug haha) you can make anything work well. Probly the best microtec is the LT12s. Great for variable cam timing aswell apparently. If you want over kill and have deep pockets go for motec but i dont see what all the fuss is about...so what if its got bells and whistles..will you ever use them?
Ive heard only good things about autronic aswell
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
