awsome thanx guys...reason i was asking is that i just replaced my turb's and i noticed the so called standard ones i was replacing had Garret stamped into them.
And yes R33God i thought the same as you, but by the looks of things they are Garret,
well i spose you never know until you ask hey.
Edited by Borgs
