OK so here it goes. USE THIS AS A GUIDE ONLY. SORRY NO PICS, VERY DARK WORKSHOP AND CRAP CAMERA. so pics were crap.
The basic guide on how to remove the dash is here.
http://r33stereo.groovesystems.net/
and
http://www.cyberstork.com/cgi-bin/howto.cg...amp;imgtp=ecr33
So please follow that. Essentially once you remove the main 3 bolts shown in the tute, the whole surround can be gently pulled out from the dash. The Main surround has some 6-8 clips holding it in place.
The easies way I found to remove it was to slowly work my way around, from the centre working my way out to the driver window.
You may also need to remove the surround, around the steering wheel. I did, as I have an SAFC mounted to mine, so I could not slide the main surround out.
Once you have the surround free from its clips, undo the wiring loom for the switches, there is 3 in total, hazard lights, rear demist and power mirrors. You will also notice a small single lead wire and a hose going from the main dash surround to somewhere under the dash. This is the hose and sensor for the climate control, disconnect these.
With all the looms disconnected and the main surround free, you can tilt it forward and remove it. BE CAREFULL NOT TO SCRATCH THE MAIN SARROUND. I DID, BUGGAAAAAA.
With the Main surround out, you will see the cluster has a bezel on it, it is held in place by 4 bolts. Remove these. This will expose the cluster and the bolts holding it in place.
With the exposed cluster, undo the tree bolts holding it in place. Once removed the dash can be lifted forward. DO NOT forget to remove the 3 looms connected on the back. This is a job for someone with THIN fingers. The loom connectors have two clips, located very close to the cluster, and may be difficult to remove.
Upon removal of the loom and the bolts, the cluster can be lifted out.
Take the cluster to a table, place it on something soft, so as to not scratch the front glass part.
To remove the glass, you will find tabs around the cluster, simply press down on these and apply pressure to separate the glass form the cluster, there are 7-8 in total. YOU NEED TO REMOVE THE WHOLE GLASS AND BEZZEL.
http://www.cyberstork.com/cgi-bin/howto.cgi?sel=cut2
(Follow above link)
Once removed, you will have the dials and cluster exposed.
NOW, what I did is marked with a white board marker, a dot on the white dash part, the plastic, where the locations of the stock dials are.
The best way to do this, is to rotate the dial with your finger, GENTLY, until it stops, this is the position in which the dial has to be reinstalled in. So what I did was to move them till they had reached the end of their travel, and put a dot on the plastic, with a whiteboard pen showing maximum deflection. ALSO NOTE THE HIGH OF THE DIAL FROM THE FACE OF THE CLUSTER.
Once you have marked up where the dials are suppose to sit, remove the dials.
EASIER SAID THEN DONE. I was petrified doing this. Best way to do so, is move the dial to its maximum deflection, and keep turning the dial slowly and GENTLY. This will spin the dial on the shaft, keep going backwards and forwards, while applying upwards force, and the dials will pop out.
Once all the dials have been removed, remove the old faces. These are stuck on with tape. Get a small knife, like Stanley knife with a long blade, and gently put it under the face, between the plastic and the face. Wiggle the knife around; until you have separated the face from the dash. When the old faces are off, remove the needle stops as per instructions.
The boost gauge has to be unscrewed, while the others simply come off. Once the old faces are removed, it is time to remove the speedo as per instructions supplied.
Fallow these, along with the adjustment specified. This is the easies part of the job.
Once the speedo is back in position, it is time to put the new faces in. Simply follow the instructions. This involves pealing of the sticky back, and gluing the faces in, ensuring all line up holes and markers are sitting in their correct positions. The boost gauge has a small black surround to reinstall as well, and you will need to undo the tacho light bar, you will see what I mean.
Once the new faces are all reinstalled, it is time for the needles to go back. DO not install the stops for now. The needles need to go back in their original locations, the ones that were marked up before. ENSURE the hight of the needles is about the same as before and their locations are correct.
DO NOT WORRY if these are not spot on, these can be fixed easily later. Once all the dials are in and connected, take the cluster to the car, without the front glass in place. BE VERY CAREFULL NOT TO BREAK THE NEEDLES CARRYING THE dash around. Reconnect the dash to the loom. Turn the car ignition to ON and ensure all the light and needles work. The boost gauge should sit at 0 with the ignition ON. If not readjust the needle so that it does.
Turn the car on, and see if the tacho is sitting correctly at the correct RPM. Check the water temp, fuel gauge and oil pressure gauge for correct operation.
If any of these needles are not quite right, simply rotate them around till you meet some resistance, and give them a slight turn to correct the movement range,
Go for a drive with a mate in another car, or go somewhere where there is one of them speed check things. This way you can check the speedo accuracy, if a little out, rotate and adjust the needed as per instructions. Once happy with all dial operations it’s time to finish.
Remove the cluster again, and reinstall the stops. Reinstall the glass and bezel for the cluster and put everything back in revers order.
I am sure I have missed something, but this is just a guide. It took me 2 hours, in VERY dark workshop, but that included putting new LEDs in the AC unit, and other switches.
This is a great mod, and the kit is superb. It looks very good during the day and at night with blue LEDs it looks insane.
Hope this may be of use to some people. I will post pics of new blue dash tonight.
Sorry fixed now.
THIS IS THE CORRECT LINK
http://www.cyberstork.com/cgi-bin/howto.cgi?sel=img
Also here are some pics of what it looks like with the new cluster and blue leds. Sorry about the quality, my camera is soooooo old.
It's mainly the photo and my LEDS, with standard lights, they are thesame, i have LEDS behind mine, off eBay, and they are not as bright as i figured at first. BUT my camera is sooooo old, hence the crap photos.
  • 1 month later...
how does your speedo work correctly if it was originally designed to work on a 180km/h gauge and not a 300km/h ??
wouldnt something need to be recaliberated or something apart from sticking on a face with a bigger range?
  • 3 months later...
hey can someone help me with the installation please...
i tried mine tonight and it was down by about 10km. ive got the instructions but im not sure about which to solder exactly...
or if im sposed to join em etc etc... i tried a few diff combos or solder this and that :whistling: but made no differance...
do you just solder across the selected points, or also join em with the other specifc ones ????
the needle also seemed to be ok. it sat on 0 on idle. and was fine until i got to about 40km/hr, then it started going less by about 10km. had my pfc and gps to check speed.
stupid oil gauge, when i turn the car to on it starts moving up which doesnt sound right considering the engine is on ?
can someone exlain how you put the needles back on so there calibrated properly, i got it working for the tacho/speedo/fuel but the other 2 arent playing nice :~(
done this yesturday, first go, when i started the car, the speedo jumped up to 33kmh at stand still.. i adjusted the needle a bit lower and its fixed now.. the only thing is, at night it doesnt light up everywhere evenly, not sure if its my stock LED or the actual design of the cluster..
either way, im happy with it, great buy..
cheers!
also added a pic..
Edited by EVL-R33
  • 2 months later...
  • 3 weeks later...
what wattage bulbs are you using i found mine had 5 watters in there and they were to bright so i dropped to 3 watts which is pretty good if you have 5's in there they might get a little hot for the thinner plastic
Edited by SevenAngryPenguins
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
