Hey guys. Decided to sell my R32GTR as ive decided to go down another path, and financial reasons. I belive this to be one of
the nicest gtr's in perth. I spent over 6 months looking at gtr's before i bought this, and none where anywhere near as good
as this. Details are as follows.
June 1994 R32 GTR (one of the latest rego'd in perth)
Silver in colour
The car has been in aus since late 2001, first owner in aus was in melbourne and barely drove it. The second owner (SAU
member) purchased it in early 2003 with just on 50,000km on the clock, and completely stock. I purchased the car of a gent
called Rob, (car use to have the plates 'ROBZILR') at the end of january this year.
The car currently has approx 118,000km on the clock and is it good cond.
Most of the modifications where done by Croydon Racing Developments when the car was in melbourne.
The car comes with all receipts for work done to it while it was in Aus (3 folders full).
The car has run 11.8 @ 191km/h in full street trim at quinana motorplex (printouts will come with the car)
Lots of parts on the car have been replaced while the engine was out (for the turbos fitment), timing belt and all new
bearings and associated tensioners, heaps of hoses and clamps in the engine bay have been replaced. Complete New gasket kit
on turbo side of engine, as well as TOMEI intake Kit. The Welsh plugs have also been changed at some point. Clutch and Brake
slave cylinders have also been replaced.
Car also comes with a straight 3" pipe that replaces the cat, and goes straight to a flange near the diff, eliminating the
cat and middle muffler.
Car comes with numerous stock items like ecu, shift knob, air box and cam cover.
The car has been resprayed during the start of '06 apart from the roof. Paint is still immaculate, apart from a couple of
minor scuff marks and a chip on the front bar.
The Car has recently been tuned by Simon Birch Tuning, and is putting out 400rwhp at 1.2bar.
HKS GTSS Turbos (only 7000km old)
HKS front pipes
SARD fuel rail
SARD fuel regulator
SARD 700cc Injectors
NIZMO fuel pump
MINES dump pipes
New Exedy clutch
HKS TOP SECRET cam gears
APEXi Power FC
TRUST Clear Cam cover
GREDDY Timing Belt
N1 Water Pump
High Flow 3" cat (also comes with straight thru pipe with no cat, for track use)
TUST PE II cat back exhaust
APEXi Pod Filters
TRUST Profec B Boost Controller
TOMEI Intake Manifold Gasket Set
NEW GENUINE NISSIAN Turbo + Manifold Gasket set
NISMO Oil and Radiator Caps
High Octane oil catch can
New Battery
DBA 4000 Rotors
RB74 Pads
N1 Headlights
TEIN TYPE FLEX coil overs
NISMO Front and Rear Strut braces
NOLTEC Front upper controll arm bushes
WHITELINE radius rod bushes
WHITELINE rear subframe pineapples
NISMO Engine Mounts
NISMO Urethane shift knob
Clarion Cd player
Boston front and splits
Pioneer rear speakers
DEFI boost gauge
DEFI oil press gauge
DEFI controller
APEXi Rev Speed Meter
Stock Forged R32GTR Rims with Falken Semi Slicks (car does not come with the work meisters in the photos)
Thats all i can think of at the moment.
Asking $27,000
Contact phone number 0419911743
Located Perth W.A
If your genuinely looking for a real gtr that will give u plenty of great driving experiances for years to come, then this is
your car.
If your looking for a cheap bunky 89 modell gtr for 18k, then look elsewhere.
Any enquierys dont hesitate to call/txt/pm me.
-Mike
https://www.sau.com.au/forums/topic/160167-fs-1994-r32-gtr/
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
