well i tried removing my o2 sensor the other day, it has come off 6 months ago when i changed dump pipes..
after my efforts the other day my ecutalk is telling me the o2 sensor is really really farked now, not just farked.... o2 is reading between .00v to .99v at idle... car is running like total crap and conks out when left for 1min or so...
now that i know its totally farked, reckon i just bash the top off it with a hammer and undo the bottom part with a socket set? have to get it off, and ive got a replacement here...
ive unplugged it and its running .30v which is cold start now so it will run rich as....
any opinions or ideas?
thanks all
Ed
https://www.sau.com.au/forums/topic/160243-o2-sensor/
ive tried just about everything else, when we got it out of the old dump it was put in a vice and a spanner and breaker bar was used!
this is looking like the only way, used a spanner, breaker and hammer in my driveway but couldnt get it off!
smashy smashy time!
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975468
Yikes!
Get some innox or some kind of rust-easing spray onto it overnight. Then give the ol' spanner another try.
OR... if you don't care about the old one, the bashing the top off to get a socket on will probably work too... if you get more leverage on the ratchet than you do the spanner.
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975609
wd40ed it over night, still no luck
i think when i was attempting removal the other day and hitting the spanner with the hammer its farked up the insides even more
dont care about it, do guna smash it goooood
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975634
UPDATE
the right size spanner, some wog power and juggernaut power we managed to get it off without breaking it
pitty i wanted to smash something....
new sensor is in and reading alot more smoothly, although there are still some variations in the voltage i think thats because its running rich due to the tune...
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975817
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
