Did an oil change today and used motul due to it being more readily available here than my regular drop.
Whilst at repco I saw an all synthetic from penrite called SIN. Has anybody had any experience with it. Going by the price it would want to be some good schizzz.
https://www.sau.com.au/forums/topic/160255-penrite-sin/
Its the one I was telling you about. 5w60 >_<
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975671
My mechanic would agree with that! He thinks using any penrite product is a sin!!!
HAW HAW HAW!!!
A mechanic I know would say anyhing else is a sin! >_<
He has been trying to blow up his 200 000km stock bottom ended 350awkw GTR for years and cant...he attributes some of his lack of success to this oil!
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975700
I used to use Penrite in my first 33....I liked it and it was recommended by quite a few workshops...I reckon this stuff would be pretty good..they seem to know what they're doing...I used Motul in my other cars though...and also found that to be reasonably good.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975710
yep, penrite has had some good history on its side. A few racing cars and been making oil for donkey's years etc....
Tried motul and switched, I've been using the royal purple and really happy with that. Great oil temp and pressure stability, good friction resistant and seems to come upto pressure quicker (than the motul i was using prior). On the skyline I think the royal purple has the history and the creds- especially with hi end gtr's etc. A lot of top jap workshops have used the royal in the past.
That's my pref, for what its worth...
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975820
A mechanic I know would say anyhing else is a sin! :laugh:
Haha, I think most of the top end oils in fairly stock cars (ie a bit of boost etc) are pretty much the same anyway.
I guess at least the penrite stuff is somewhat Australian.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975848
Redline or royal purple would be my choice but its too darn hard to source here in the switch. :laugh:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2976280
I didn't say it was MY opinion, why is it necessary for me to back it up? I was simply stating that many people would prefer other oils over Magnatec in particular.
Oils aint oils?
Anyway i am about to try Mobil 1 5w50 in my car next service.... then im going to try the Motul Semi Synth 5w50 and see what the difference is.. i might also try a Penrite as i put it in my Gf's celica with 200,000 on the clock and it now works a damn treat..
I use to use the semi synth Motul in my silvia and it never had a problem.
Guess i will just see how it goes..
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977740
I have been using Royal Purple for the last 40,000kms and love it previous owner used ELF (not sure on details) but engine did feel better with the royal purple in it. Wont be changing to anything else from my experience so far.
Interested to know what price is this Penrite SIN?
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977910
HAW HAW HAW!!!
You would make a good redneck man.
I use 10W60 Catrol and my engine has never been better i think.....
WTF is Royal Purple??
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977980
Hmm that rimindes me, i should start putting better oil into my 200,000 stooooockoooo lancer. that isnt my dads crap "BALCK AND GOLD!!!"
plus when i finally get that lovely peice of laminated License i will be giving him a full detail :glare:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978267
giving your dad a full detail?
talk about keepin it in the family.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978288
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
