Hi all,
Up for sale is a set of R34GTT Standard Side Mirrors (complete) in QM1 colour. They are in excellent condition.
Price: $150
Contact: PM or email to stan[AT]2evolve.com.au
Reason for Sale: They're just lying around in my room...
Thanks
Stan
Hi all,
I have up for sale a complete set of R34GTT Standard Injectors (blue). They are in excellent condition and were in perfect working order when taken off my motor. Injectors have been stored in individual plastic + boxes (from SARD) since removal.
Price: $150.00 delivered via Express for all 6
Thanks
Stan
EDIT: NOT FOR SALE AT THE MOMENT
Hi all,
I have up for sale a standard R34GTT Fuel Filler Panel / Flap in QM1 colour. It is in excellent condition.
Price: $15 + Frieght
Contact: PM or stan{AT}2evolve.com.au
Thanks
Stan
Hi all,
I have up for sale a standard R34GTT Automatic Shifter Knob (black leather). It is in good condition and the reason for sale is because I now use the Nismo one from Momo.
Price is $30.00 delivered
Contact: PM or stan{at}2evolve.com.au
Thanks
Stan
Hi all,
I have for sale a R34GTT Standard Fuel Pump + Intake Sock. Taken off my car due to upgrades; in perfect working order.
Price: $50 delivered
Contact: stan{at}2evolve.com.au or PM
Thanks
Stan
Hi all,
I have for sale a R34GTT Steering Rack... purchased as a whole so I could take one of the arms off for a repair job. Rack is complete and in good nick.
Price: $150 (pickup prefered as it's quite hefty)
Thanks
Stan
Hi
Up for sale is a standard set of R34GTT Caster Rods (pair). They are in good order and the reason they were removed was so they could be upgraded to adjustable items.
Price: $30 + freight (pickup preferred as they are quite heavy)
Thanks
Stan
Hi all,
I have for sale a R34GTT BOV Cross Over Pipe; perfect for polishing or custom BOV fabrication. It's in excellent condition with no dents / gashes.
Price: $50 + Freight
Thanks
Stan
hey Stan, on a side note, have you changed over the pipe that runs from the AFM to the turbo (the one that sucks shut if you run over 1 bar) .... I can't find these for sale anywhere ....
Hi all,
Price: $200
Thanks
Stan
Hey Stan,
Are these off your 2 door or a 4 door? Is there any difference do you know cause my left mirror motor not the actual mirror but the one which controls when the whole mirror thingy moves in closer to the car when you press the recline button is stuffed.
1) No airbox available anymore - Nightcrawler; if you can help this guy out please do so :unsure:
2) Lanky; the mirrors are off my 2door and I'm 99% sure that there is no difference between the 2/4 door mirrors. Since you are in Epping you are more than welcome to come see them for yourself :P
Blue injectors are standard on the R34GTT - you should inform them of this.
I managed to pull 210rwkw before they maxed out; others have managed to pull more from them. Regardless; if you're chasing big power then you need bigger.
Nonetheless; these ones are NOT for sale anymore.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
