Introductions And Are Any Sydney Cruises Being Organised In The Near Future?
Hey guys first time posting so nice to meet you all.
Was just wondering does anyone organise any Skyline cruises on a regular basis in Sydney?
Oh and by the way heres a couple shitty quality pics of my series 1 R33 with over 300kw at the wheels.
Let me know what you think guys, be honest!
yeah no worries, well if u ever up for an awesome little cruise which involves runs up tthe old pacific highway, then your moer than welcome to come allong on thursday nights at 7 30, at berowra truch stop. i know its a bit of a trek but its great fun, we cruise up to the central coast to meet with coasties thread.
hey mate, welcome ;)
there is a massive *apparently* cruise taking place on sunday - Nissans and Hondas...
http://www.skylinesaustralia.com/forums/in...howtopic=159731
Welcome,
Whats done to get 300rwkw
Thanks for the input guys,
Had this car for about 6 years, in its current form for about 2, sorry no pics of engine bay but will post up in future, (engine bays dirty as hell, like it that way, means that its working hard!)
Mods off the top of my head include,
T3/4 turbo, forgies, intercooler, big wastegate, 3L bottom end, injectors, fuel pump, etc etc...
Stock top end, next upgrades include, cams, headwork plenum, see if im up to spending more money on it.
Hi Welcome :glare:
There is always something going on check out the event section to see the up coming events and there will be a SAU monthly dinner held out west next month but more then welcome to come to this months dinner :laugh:...
and it definatly helps to become a member of NSW SAU so keep that in mind
Hi Welcome :happy:
There is always something going on check out the event section to see the up coming events and there will be a SAU monthly dinner held out west next month but more then welcome to come to this months dinner :D...
Thanks for that, and just as I read your post I signed up to become a member, so all is good! :P
SAU NSW ftw :happy:
Sounds like some nice mods in there - should bring it to the SAU NSW Drift day on Easter monday :D
Thanks mate, definetely might come down and check it out, but it is double demerits, and cops absolutely hate my car!!!
now that you have joined (and good stuff by the way :happy: ) have a look at the drift day info - put some stockers on and enjoy those 300rwkw sideways in a controlled envirnment :D
Thanks mate, thanks for the info, im in the inner west, Balmain area.
i grew up in balmain, thats my ghetto!
not so many cruises, more dinners, (getting really loose!), alot of track days and just general meetups....
welcome.... hope you enjoy your stay
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
