I should also say that I remembered reading somewhere that the the RB26DETT crank nose is larger in diameter than the other RB engines. If this is correct, then the ID of the pump gear will also be larger. I can actually confirm this if you like as I have an RB26 oil pump on the bench, and RB30E one (buried somewhere)....let me know.
As for the water pumps, don't know for sure, but it's possible the RB26 type would have a higher flow rate as it has to feed 2 turbos - but then again, the same thing could be achieved using a smaller diam pulley....
Good question Joel, :)
I think Tomie/Jun? make a adapter for this. I just have to speak to a few people and see who sells them. I havent started looking for that just yet. As i am trying to find a set of good cheap forgies, i think there called Aries? "rocket industries" make em. got a quote off a guy on here for $1100 with rings!!! :)
So iam just buying all the little cheapy bolt ons that i will need for later, like this oil & water pump. But thanks for bringing this to my attn.
So were are you at with your RB30 build? progressing?
PS: if you find a place that sell them, drop me a PM.
PPS: also for oil squirters.
Cheers,
Joel!
Let me know where you get the jun adaptor and pistons etc.
Do the pistons have to have provision for the oil squirters?
Or pistons are pistons oil squirters or not?
I'm using the oil squirters from my RB20DET.
I'm at the stage where i'm just getting all the bits together.
differences between rb30 and rb30t are as said above , plus the rb30t releif spring is about 4 mm longer.
the gtr pump is i think same size as rb30t pump , but has different shaped gears and the releif valve is slightly larger diameter.
best to check though.
a mate is using a gtr pump on his vlt
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
