The price is pretty good if you don't need to worry about organsing to buy it, you can get it cheaper elsewhere depends on how quickly you want it. $240 seems okish for an install hope that also includes them configuring it as well ???
---Updated---
Nengun = AU $ 503.36 + shipping = $546.30
Greenline = AU 503.735 + Shipping = ???
But keep in mind that these ones you may also have to pay import tax etc so i would actually buy it from him unless you want to get one second hand.
Also depends on if you are going to buy another ecu later. If you are then an AVCR is probably overkill. It does some of the simple things that an AM ecu does.
If you can get a boost controller for sub $400, then you are wasting $200? but if you don't intend getting an ecu for a while then the AVCR is a good cheaper compromise.
I was told the PowerFC boost controller plug in was not soo good.
I'd love for someone to actually show me some funky stuff with the AVCR when i do my high-flo upgrade.
The standard ECU will remain in place, I doubt it will ever be replaced. But it is being retuned by CEF11E once the turbo is finished being high flowed. I’m also getting a bigger fuel pump put in. so I think I should be pretty happy with the final product. Edd at Integra tells me the turbo should have no problems doing 220+ rwkw. But as far as I know I will probably need bigger injectors. As I think the standard RB20 items will only flow enough for around 200rwkw
I wasn't saying not to buy a boost controller. The pfc one is OK, but basic, you would better with a dedicated evc no arguments from me there. What I was saying is that an AVCR is a boost controller plus a boost response controller. This is also done and done much better by a pfc.
If you aren't getting a pfc then its no problem = spend an extra $200 and get the AVCR.
If your plans include a pfc then get a $400 boost controller and put the $200 you save towards your pfc.
PS See this: http://www.skylinesaustralia.com/forums/in...howtopic=162435
re: spiking?
My understanding from the manual, is that once you start to spike you need to work on Solenoid duty timing and the like.
Of course this requires more work and testing, but i plan to let people far more knowledgable than i tune the bejesus out of it at the time.
I-Colour - very nice. Haven't read all this thread but I just had one fitted and I think it's the "ants pants". Yeah it has heaps of functionality and 4 boost settings which may well be deemed overkill. However, I like it 12, 15, 18 and 22 psi. It's going to be nice to go to the track and just select channel 3 (18psi) 300 awkws, boast or boost :)
It's extremely precise and very easy to use, configure/set. Gets my vote also for the amount of info that is displayed.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
