HI GUYS I HAVE A RB20 DET AND WHEN YOU GIVE IT A BIT IT SMOKES BLACK I NO ITS FUEL BUT WHAT COULD IT BE SO I CAN FIX IT IF CAN THANKS
uhh... not running fuel thats too rich would be my first step. possibly a service? what injectors you have atm? any mods to the car? you'd need to give a bit more detail...
deriq.
deriq.
hi IT HAS HAD INJECTORS CLEANED STANDED IT HAS FMIC BLOW OFF VALVE AND AIR POD AND 3 INCH PIPE WHAT FUEL IS TOO RICH THANKS
That's a standard Skyline problem. The ECU will enrich the mixture toward the top of the rev range to prevent damage. Have a look at the back of any turbo car when they "Give it a bit" they will all blow a little black smoke.
deriq.
whats 'fuel thats too rich?'
very true. if its a little bit of smoke, its normal.
blow off valve makin the car run rich, put your stock one back on and it should stop smoking
blow off valve wont have anything to do with the on-throttle fuel mixture.
if its not the usual skyline scenario, my guess would be the afm as mentioned, o2 sensor or timing.
check all 3.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
