Item: Power Fc ECU Only ( No Hand controller - Not necessary for tuning/driving of the car)
Item Condition: Used - Excellent Condition
Reason for Selling: Upgrading
Price and Payment Conditions: $500.00
Pictures: Google is your friend ;-)
Contact Details: 0402846861
https://www.sau.com.au/forums/topic/160726-power-fc-for-rb26dett/
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
