hi guys
Just having a browse on the UAS website and came across their 'cold air induction' snorkel and 'UAS alloy air box' for the 32 GTR
Unfortunately there arent any pics next to the items.
Is anyone using either of these on their GTR? Or do you have any pics?.....even past experiences with these products?
For the price they dont seem too bad and if there is actually a decent and cheaper alternative to the ARC box that enable you to keep pods, then im all ears :(
Heres the link for a reference (nismo.com.au ->products -> intake and cooling)
Btw they list the airbox for $195 and snorkel for $250
cheers
https://www.sau.com.au/forums/topic/160806-uas-32gtr-snorkel-and-alloy-airbox/
thanks for the replies guys. I wasnt looking for pics on cars, its just when i looked last night they had no pic next to the description.
it looks as though the snorkel runs from the front bumper slits and then up through the guard which would be just as effective as my set-up where ive run some ducting through the bumper slits, through a hole in the guard and into the front of a modified stock airbox which is a complete sealed system.
And youre right, the 'air box' is simply a cold air partition. thought it was too good to be true :D All though ill give it kudos, it looks nice and would do an ok job with a cold air feed whilst letting you retain pods
so where it stands : made my own snorkel and cold air feed for $25 (cost of piping)
Bought a GTR airbox to replace pods and modified for free $150
All up ive spent $175 instead of $445 plus postage and can sell the pods to cover costs. yay
Now the question is...would their costly setup be better? More people should give the stock airbox a chance :huh:
heres the pics as requested...
you can see the ducting from the front bumper. I had to squeeze it through the little gap and lube it with some vasoline haha cause i couldnt be bothered taking the bumper off.
This ducting goes up through the guard and comes out in front of the airbox.
I had to hacksaw some of the lip off the airbox where the entry is. Where the plastic snorkel would normally attach to. What this does is give the ducting a straighter path into the airbox which keeps the diameter of the ducting at its largest.
i bought the ducting from a motor shop and its the Monza brand and is just ribbed convoluted tubing, about a meter in length. Approx 4 inches in diameter.
the airbox doesnt sit as flat as id like it but the bonnet still closes
The airbox is also against the Greddy pipe but i have orientated in a way that both can be friends (ie. rotated slightly)
Resonator? Is that the plastic behind the headlight that the original snorkel plugs into? i wondered what that was. how do i remove it?
nah see in your second pic through the duct there is a plastic thing that looks like little squares of chocolate? that's the resonnator (see pic)
that runs up into the bottom of the airbox AFAIK and keeps intake noise down or something... lol
mine was full of water so we binned it lol
ohhh i wondered what that radiator type hose went to
i guess anything that saves weight is worth getting rid of.
Whats the best way to get to it? front bumper off? or go from the top?
cheers Ronin
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
