Sorry to hear about this too Max, thinking of ya.
That sucks major bollocks...
I used to have a good panel beater but lost track of him. If you wanna sell the wreck though as-is let me know cause I know a guy that will probably take it off ya [for a price of course ;]
  • Replies 89
Sorry to hear it Max but at least you're ok.
Alan
P.S. I dont think a cruise to Phillip Island would be the same in a mini. And where you said that you "never really think the insurance is worth it" well if I couldnt afford the insurance I wouldnt drive the car but I suppose you dont need to hear that now.
OK guys i've gone to have a look and i've taken some pictures. I will post em up as soon as i can (later tonight).
Basically it appears all that needs to be repaired is everything in front of the engine. i.e. the radiator support panel (the major thing) and replace the 2 front quarter panels, bonnet, headlights, front bar. not cheap, but i don't think its 8k worth either
anyways you'll see what i mean when i post the pics.
yeah man get some quotes b4 you right it off and get it out of the wrecking yard and home
thats the best even if you have to pay for the tow make sure every thing is in the car.
this sux but your still better off when you think about it insurance wise.
hunt around for the parts and I reckon you could get it fixed then if you feel that way do what to fardown said and sell the car.
shit happens to all of us I poped the motor in my cefiro and it sux big time but what can I do you jsut fix it and move on
meggala
Do the doors still open and close without hitting the front guards? Is the roof buckled at all? Are the front and rear windscreens still intact? Does the engine start and run? Did any oil leak out of the motor/power steering when the impact occured?
You may have someone interested in purchasing it, post further details.
damn NOOOOOOOOOOOOOOOOOOOOOOOOOO, you havent had it that long either ;) *crys*
i never knew that the support behind the fron bar offered protection... DOH! i just had mine cut away to fit my intyercooler, hopefully my intercooler qill protect me in case im unlucky too (its ****ing big enough it should)
but live and learn biddy, unfortunately it seems like it wasn't really a 'mistake' so to speak, you just got unlucky for a split instant :( thats why i hate my car in the wet :(
i feel for ya bro :(
bozz: the passenger door doesn't open without hittin the guard, but thats because the guard has come off itself, the chassis has not bent. The engine runs but it leaked some sort of coolant but i believe it was from the air-con. No roof buckling whatsover and windscreens are completely intact. I reiterate that it was a very low speed collision.
The car itself is definitely not a write off in terms of damage, far from it, its just a matter of whether i can afford to get it fixed or not.
Put it this way, i have a pretty big pod filter and it survived completely intact, and it was always very close to the left-front of the car where the centre of the impact occured. The right head light even managed to survive.
i'm going to post some pictures up now, but most of them came out blurry (crappy digi-cam). You can get an idea tho.
ehh Maximus im so sorry to hear man!!!
If I was in your position I would probably wanna kill myself, although thats not a positive thing to do.
So I would get quotes from all over the place and see if this dude that quoted u $4,000 just for labor is pulling your leg.
I know a guy named Jim Spena, whom is a family friend and he owns Glen Waverly Pannels, he does a top job.
When I had my first car I did a handbrakey into a keep left sign smashing the rear quarter pannel. They had fixed it, taken out all my dints and gave it a respray and the car unfortunately a lancer looked brand new just better paint. The sprayed it with 2pac paint made it nice and glossy.
If I had to reccomend a place I would reccomend them, If you decide to see what they have to say tell Jim that Mark Kearns told you to go there.
If you did get your car fixed, I think its worth keeping it.
But thats my opinion ;)
take care mate
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
