well i got my rb25det r31 and it free revs well.
But once you put load on it driving it starts to rev and then breaks down and wont rev, and starts backfiring as if it was a limiter noise...
when you change gears the bov makes a high pitched whistle instead of the normal rb25det bov noise, but thats in 1st and 2nd but from 2nd to 3rd and 3rd to 4th and 4th to 5th it makes the normal noises...
and when you do the limiter revving under load noise when you put the clutch in the revs drop down then it revs back up
free revs all the way out but wont rev under load
what could it be?
https://www.sau.com.au/forums/topic/160907-rb25det-breaks-down-under-load/
coil packs or spark plugs. there are a few different fixes for the misfiring problem.
#1 - gap your spark plugs to .8mm (do that if not already done)
#2 - fix your coil packs, there are a few threads around on how to do this.
as for the bov sound, im not too sure if this fits the sound you described but it might be turbo chatter, where your bov doesnt actually open, the noise you're hearing is the air passing back onto the turbo blades.
Hey you are reading my mind but about four months earlier, If you have played with intercooler and a boost controller on the car you would have noticed that a nipple would be missing on the inlet part of the pipe before the bov that is the vacuum pipe that opens the actuator on the internal waste gate and if you dont have that hooked up you will hit max load causing seveire breakdown at 2k trust me i had the exact problem!!! easy way to fix it is to simply put a T valve in on the blow off valve hose that goes to near the back of the plenum!! that will get rid of your break down at 2k.. P.M if ya want a photo!
made a slight difference but still breaks down, but you can get past the banging and then it tries to pull.. could it be a fuel problem?
but what concerns me is, i gave it a boot full and then went to go into my driveway, stopped and the car stalled, then i started it again and it stalled again but started it and gave it a rev and it idled fine...
its quite farken easy u see...
u get a gapping tool, pick the gap u want, get ur spark plug out, tap them on the ground softly until the gapping ruler u are using fits between the sparking element and the underside of the tip. ur spark plugs come pregapped at 1.1 thats not enough for boost past 6-7psi. that will work, if ur unsure how to do it, go to ur mechanic.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
