Sorry I didn't get your call Tosh - was fast asleep after a very very busy day at work today. Matrix Reloaded is going off, needless to say I guess. :D I've got my car back now with a new set of rims to get me by for the meantime, but I'm quite happy with them so I should keep them for awhile, car seems all good so far.
https://www.sau.com.au/forums/topic/16100-tonight-1605/#findComment-331247
    • lol the 2nd one boss, thank you for pointing this out. I feel as i spend more time here this intro message is some thing i will always make me laugh and shake my head at. Perfect Intro:  I have the vehicle
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
