Hey Guys,
I live on the sunny coast and my friend and i both own skylines. We were out one night and i was going home from a party, my friend was parked out in mooloolaba and saw a whole crew of skylines drive past, hot ones too. Just seeing if anyone knows anythin about it? haha he went driving after them but couldnt find them :) . we all seem to hide until night time :pirate:
https://www.sau.com.au/forums/topic/161437-sunny-coast-riders/
oh thats a shame. There isnt really much else to do but enjoy ridin in cars and showing them off, unless of course there was a nice open area to have some fun. haha an abandoned air strip! Dont suppose you know any place that may be good to 'practise' some driving :pirate:
Showing off cars is ghey and has no purpose :)
We used to do mountain runs until someone came off, and the media started to publish things in the paper.
well why do you do up your car if its gay? :pirate:
i know of a few places in bli bli, and also the huge bends on the way to yandina is pretty sweet. there is a nice long straight there, although not the smoothest
Satisfaction for me is winning, not what a car looks like. But everyone has different views on what they like.
Serious though, head down to Brisbane city and down to Gold Coast, there isn’t a huge cruise scene up here, it's pretty much just local younger kids on a Thurs night and much the same on a Sunday arvo. Go check out BWCP, that whole parking lot is normally full every Sat night.
yea i may do, my friend lives there and usually comes up every weekend.might go down there for a change. im stuck with a NA at the moment. i chose to get my car completely stock and personalise it myself, so in a way i know what you mean. but you have to have the looks to go with performance. My friend is also telling me to sell the one i have now and to buy a stock turbo cause i wont get the same benefits if i just put in an aftermaret turbo now. i know it depends on what type of turbo but it would have to be better than the stock ones, what you rekon?
you rekon? so no matter the turbo put in, it wouldnt be worth it?
Also just read up on BWCP in brissy, supposedly its a death trap, it was a good scam by the cops and you can get defected for anythin like your wipers being too hard or not enough water etc!!! how stupid is that. i was reading up another forum where no one was allowed out until their car was checked and some people waited up to an hour!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
