You got a dyno readout on that R34 Trent
also what supporting mods did it have im looking at trying for around 270 myself
and was it a standard auto ?
will get it up 2moro, yes std auto.
  • 3 weeks later...
  • Replies 765
Trent, I still cant convert my car to run with the MAP sensor. it idles okay, but if i put my foot down it hesitates then revs. its also hard to start. i spent 2hrs getting the maps right, even used the inj map to adjust fuel but its still not good enough to drive around with.
any clues?
Hey guys, i've picked up an innovate LC-1 - have many ppl connected these to their emu?
any detailed setup/instructions for R34 GTT?
i was talking to a guy in perth that had everything setup, but the emanage forum is down and i've lost contact
  • 3 weeks later...
Hey Pear,
Your lucky day - I'm the guy from Perth :P
I've attached my notes - An Excel Spreadsheet with 3 tabs. each tab shows a device (LC-1, Old Oxygen Sensor, EMU) and what the cables were connected to and should be changed to.
I made my own EMU front panel connector using a internal computer audio plug - worked better than I expected. The hardest bit was running the wiring between the engine bay and the cabin.
LC-1 is working great - I've used the EMU auto tune function to help home in on my desired AFR. On to Knock and ignition timing now, but I've hit some sort of turbo pressure issue I've got to sort.
I'm also spewing the emanageforums site is down - what's going on there!
Hope this helps,
Scags
LC1_Skyline_ER34.zip
you are pretty sort after guy at the moment Scags LOL
Im also chasing that info
And on the emanage forums I believe it had something to do with the stockmarket crash
Pear knows more
Edited by Haines
Id like to say this is probably the best info on the EMU i've seen on the net and I've been pouring a ton of hours in searching, much thanks to URAS and all others who know what they are doing with the EMU,Anyway..
Had a few questions, Ive got a series 2 Rb25det ive stuffed into an S14, all S14 wiring gutted and nothing but R33 wiring in it. (yeah I live in the states)
Ive got an EMU that I'm about to wire in and plan on doing the AFM elimination.
So after I log the greddy pressure sensor vs. RPM and get as much data as possible and put that into the airflow output map and interpolate the rows and such, get the numbers looking and working good... Im guessing im going to max those numbers somewhere in that layout and hit boost cut.
Ok so I clamp the voltage rite before that happens...now the ECU never sees the voltage but i still need fuel and timing correction beyond that point, soooo.....
Do I go to the injector and ignition maps and put in the values i need there? or do I use the aux. map or something else?
Also what if some of the values inputted into the airflow output map overlap something you've put in these other maps? which one wins?
Hi guys. I've just installed EMU to my car and have 2 problems. The ignition timing in the datalog show that it currently running on 110degree btdc when idling and it doesn't change when the rpm change. And also the EMU didn't sensing any knock when the engine under full load and show 0 knock on the datalog. What did I do wrong? Is it the wiring or setup in the jumper or software? Anyone can help? Thanks.
Edited by bnr32_700ps
for starter your knock should be set to resonant 7.02
and as for the 111 deg problem its a wiring prob i believe or jumper setting
Hey Haines,
How certain are you we should have our kncock set to "resonant" and 7.02? I ask because I want to be sure I can trust the signal I am getting before I advance my timing much more. Isn't the frequency dependent on the bore and stroke of the engine? Does that mean it wouldn't be the same for different models of skylines? I had a good thread going on this before emanageforums went down :( So much information lost in a matter of senconds. I hope someone is able to revive the information that had been gathered at that site...
You said I'm sort after? Who else is looking for me? :(
JJ
Ive found that it works best when you do a voltage clamp vs. throttle position. nothing else has worked properly for me.
What you can do is do a map trace and when you feel 'boost cut' change your values in the Airflow Output Map (where you're putting your voltage clamp data) to a lower value to bypass it.
the map trace will tell you which values you're reaching 'boost cut' on so all you need to do is change the values in the highlighted boxes.
the WORST issue i had was cold start with the MAP sensor running. it would run like an absolute pig. i ended up buying an EEE PC just to have in the car with only the emanage software installed so i can adjust the cold start voltage when i turn it on in the mornings!
The problem is on cold start the AFM voltage is around 1.70 on idle, then when it gets to operating temp it sits at ~ 1.06. the 1.06v on cold start makes it run like crap and VERY lean. I even tried playing with the temp adjustment map to add fuel but it only worked to a maximum of +20%, i needed at least 40% adjustment for the afr's to be anywhere near the right value to idle properly.
Trent, do you have a fix for this?
So you're still keeping the airflow output map on greddy sensor when doing all this right? and doing all the clamping there and not even using the boost limiter map?
Edited by antomx
Hmm not had this issue, i would try juggling the afm voltage in the output map to mid way between the two, bit on the rich side at idle say 12.5-13 instead of 14 ish and see if you can get enough cold start in there. without playing with it here it is a bit hard sorry.
Edited by URAS
Just did a stagea and i get alot of enquiries on them so i thought id share anothr i did the other day for a fellow SAU'ER
Edited by URAS
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
