I have a R33 GTS-T and have a problem where the ABS Dash Light turns on (and remains on) around 2-3 minutes after starting the car.
Anyone know what is the cause and the solution to this issue?
leave the engine running go to the boot, on the left side under the parcel shelf lookfor a metal box with a flashing led. the led code will tell you what the error is ie 3flashes 1 second apart then a 2 second pause then 3 flashes this is error code 3 =right rear rotation sensor.
can you show a picture of this metal box with a flashing led plz.
my car is a 97 gtst with abs. this happens to me in the past .. but normally went away after another start.
when you resatrt the car ECU get king of reset or something, so you wont see the ABS light, after you driving a while it will come back up if the problem still remains. Check your barke fluid first. Have tried braking a bit hard when the lights come on? best thing to do is when the light comes on check the error code on the metal box, actually Im not sure how to do it yet. this could be due to damaged ABS sensor as well!!!
Or take it to a mchanic so he will plug the computer things to ur ECU and check for errors....will cost you $45 or something like that...I guess.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
