92 model, personal import
132000 k's
12 months rego
full service history since i have owned it by a skyline specialist, has had clutch master and slave cylinders done, brake master done and GTR n1 water and oil pumps fitted, timing belt changed, new battery fitted a week ago.
Gunmetal grey
GTR bonnet and grill
type M front bar and side skirts
R32 GTR wheels with bad rubber or 18inch RJR racing wheels with good tread left
GTR brakes with recently fitted bendix ultimate pads
Lowered 1.5 inches
Dark tinting
Full 3inch exhaust including ceramic dump pipe, Fujitsubo from cat back
Splitfire coilpacks
Just Jap heavy duty clutch
GTR inlet manifold w/custom trottle body and fuel rail set up.
ECU retune
Custom oil catch can
Upgrade R33 turbo
Plazmaman FMIC
Boost controller
HKS SSQ BOV
GTR centre console
GTR gauges with NISMO 260km/h speedo
NISMO front strut brace
Cusco rear strut brace
JVC head unit with alpine speakers
Apexi turbo timer
Alarm
K&N POD filter
This car has served me well for the past couple of years as my daily driver. Has never let me down. Car has not been on a dyno.
I have never circiut raced it but it has had about 12 runs down the quater at W.S.I.D and has recorded a best time of 13.5 seconds. This time was run in street trim, ie 18 inch tyres, full tank of fuel and stereo still in boot on a hot summers night.
Thanks
Adam
Edited by mrfrontmount
https://www.sau.com.au/forums/topic/161670-r32-4-door-for-sale/
Good Luck with the sale adam, she looks as clean as she did the day you bought her!
your old 2 door is still going hard! very hard as a matter of fact...
Take it easy, Ed
Cheers mate
Shes still in top nick for an oldie!
I will be after a Stagea now as i need to fit in wife and dogs and stuff.
On that note am interested in swaps/trade on Stags.
Thanks
Adam
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
