  • Replies 42
yeh i havent found it too be that bad! it seems smooth and stuff but i guess i havent driven with anything else before!! maybe once i get my car off DEFECTT i could let one of u take her for a spin to see what u think? but yeh she seems ok.
thanks for the replies fellas alot of suggestions, im going to go with getting a clutch myself from sliding performance, their prices are good. unless i can find the same one elsewhere.
5puk button clutch kit from SP
seems like a good price, 500 delivered, and plenty for the power I'm hoping to achieve.
Is there anything else I'll need to buy along with the clutch... i JUST changed my f**king oil (gbox) to redline lightweight and its beutiful stuff and i want to still use it as most likely itll still be blue when it comes out.
whats wrong wid you bitches....too scared to get your hands dirty? :P:O
do it yourself and spend the cash you save on a carton of piss to suck back while doin it.
its time consuming but f**k its only nuts and bolts.
button clutches arent that bad.
Edited by Ryanrb25
while your at it send your 5 speed to sims, and with the money you get buy a 30 pack of draught, then chuck a 25 auto in it and never worry about clutches again...
Just rear tyres due to those seamless first, second third 160km/h+ on the spot no brake burnouts. :unsure:
i got quoted 400 dollars for clutch fitment, machined flywheel, rear main seal replacement.
i wouldnt go there then it cost $400 to fit a clutch to my car yours should be about $250-$300 max
im booking mine into kent brake and clutch this week they fitted my last one and did a good job
if you want a quote ring tim on 8445 2055 after 8:30-4:30
The RB25 rear main seals are the same as a RB30. Cheap as chips. Also super easy to replace. A few bolts and its off, then slide on the new.
Machining of the flywheel, I can't remember what thats generally worth.
Either way $100 to machine a flywheel and replace a rear main seal, probably around the mark.
i said the above. did your cost of 250-300 include the rear main seal or the flywheel being machined?
so that means, 300 for cluctch and 100 for flywheel and rear main seal.
yes mine is fitment seal and machining
i went in today to get firm quote $450 fitting and $490 Xtreme HD clutch i just picked up then went and saw Brad Fox
remember pauly mine is AWD takes longer to do and is harder a little thats why i think yours should be alot cheaper than $400
is there anywhere in adelaide I can get a clutch for ~550 dollars and then fit it myself/ cheap fitment around.
Any help would be great, thanks.
I know its not of any help....
but I just bought a 2nd hand ORC Ogura Super Single with Cr Mo Flywheel from Terry @ Kansai Automotive for that $$amount :happy:
Top bloke that he is, even drove it down to Nisswreck (who are doing my replacement trans) himself.
Two thumbs up for Nisswreck and their service so far also.
More info please.
Wha happen?
Well, you see....
The noisey box was going to be replaced anyhows.... I was just putting it off for no good reason.
Driving on my way to lunch with Missa on Tues, clutch pedal started getting progressively sloppier and sloppier. Until, nothing at all. Just made it to Mel's work, pulled over and the clutch wouldnt disengage.
All of this = shagged clutch slave cylinder, which leaked all the clutch fluid along my route up fullarton road. I couldnt diengage the clutch once pulled over, nor could I get it out of gear.
can i get soemthing straigth here... my clutch is burnt out, it still driveable, but u need it hit boost for it to grip properly. all im looking at is a clutch replacement right? nothing else unusual is happenin with the car apart from a clutch odour.
Thats right just a simple clutch replacement.
Check out the slave cyl, and pivot ball while your under there.
If your after a slave/master cyl contact All clutch and brake listed in the workshop sticky. The blokes owned an R33 for the past 6years odd and knows what fits what.
For example... Slave cyl for mine was ~$38, master cyl was $75 new.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
