heya cara,
i ran the extractor group buy. i knew a guy who was selling his extractors since he was selling his car, but i'm not sure if he's changed his mind...
try getting in contact with this guy: http://www.skylinesaustralia.com/forums/in...howtopic=159047
we got ours from a place over in new zealand. it's been a total nightmare for me to organize it, they aren't the best in terms of communication, and i was constantly on the phone trying to chase them up. i initially only ran one group buy, but everyone wanted a 2nd one most of them have received theirs.
we are waiting on two who opted for a slightly slower delivery method. if you really want i can PM you their web address and details, but i wouldnt be promoting their services freely after the headaches i had to deal with.
the alternative is to order a set of fujitsubo from japan, you are looking at $1600+ delivery.
another alternative is RB30 extractors (easily located within australia) and having the flanges cut off and modified to fit your exhaust ports.
cheers
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005073
hey Eug,
how hard and how much headache is there with cutting the flanges off with the RB30? is it a fair amount of work that has to be done for it to fit my RB25? does it work out cheaper to do it that way?
Thanks
Cara
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005092
cara,
any exhaust shop can cut the flanges off. hell even i could do it with an angle grinder (bit dodgy though :unsure:).
a quick break down of what's involved:
firstly, you'd have to make sure that the port sizes are at least similar or the same.
then, cut off the flanges
get flanges made up and weld them onto the RB30 ones.
it's a pretty rough method, and price wise it'd definitely work out more than the prices i managed to organize for the group buy. although if you know someone with a mig and with a bit of skills, and could snap up a set of extractors cheaply then it'd work out similar.
hope that helps
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005186
any good reputable exhaust shop would be able to do this no worries
the only thing that could cause a prob is the clearance around steering components, and the angle of attachment as the rb25 is a DOHC, whereas the rb30 is a SOHC (ie rb25 head is further out than rb30, if u get my drift)
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005856
cara,
with 4 (or more) buyers in our group buy the extractors cost AUD$185ea, plus a AUD$15ea gasket, and hp coating cost AUD$170 (optional) combine that with international delivery of approximately AUD$60-70.
you have yourself a set of basic extractors for as little as AUD$260 to a fully macked out set for AUD$430'ish.
$1200 is a rip off unless they plan on using titanium tuned length with gps system built in or something fancy.
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3011358
    • You've got yourself a good old game of have fun. That shit is annoying as hell to remove. Thankfully for you, yours is on metal, most of the stuff I take it off is plastic, so typically hear guns are out. I normally end up continually dragging my thumb with pressure over it to get it to peel up. Eucalyptus oil then works well for getting residue and last remnants off.   Edit: plastic scraper might be worth while too. One that'll dig into the foam tape, but not scratch the paint.
    • So I ride and race motorcycles for fun and have always used a van to transport my track weapons. Figured towing a racebike with a skyline would be different and if done right could - "look fully sik" or quite cool for us grown ups lol. Pic of yours truly on two wheels I also have a trailer already kitted out to transport my bikes ...and I have a spare set of rims that match the car that I was going to rebarrel to get deeper dish at some stage but they have just been gathering dust. Sooooooo it is only logical.... Stay tuned !!
    • If by "flap disc" you meant "chocolate wheel".... then they are OK for getting off stubborn remnants. But not for stuff with bulk depth. If by "flap disc" you meant "abrasive paint f**ker"....
    • Beauty, thanks guys, got some ideas now. I note that none of you agreed with the flap disc so that's good to know. 👌🏻
    • I had small pin holes in my glazing putty but didn't want to put more putty to not make a mess again and I put 2 coats of epoxy primer to prevent it from rust. Though you can only see the pin holes if your eyes are almost against the panel. Do you think when the 3x coats of high fill 2k primer and 2 base coats go on that it will be visible?
