Hey guys i have a 93 model rb20 with the following mods:
-turboback exhaust
-pod filter
-turbotech boost controller
also will be installing SAFC this week.
My car seems 2 hesitate from around 4000-5500 revs every so often. More so
since the boost went up.
i have changed spark to the NGK BCPR7ES 1.1 (pretty sure thats the number)
and gapped them to .9mm.
i had the split dump pipe and magnaflow high flow cat installed yesterday which has made an improvement in other areas except for the hesitation.
I'd like to add that it mostly happens during the day and every know and again at night.
If i had cracks in the coilpacks would it be missing all the time through out the revrange or every so often like my situation.
Just want certain exact areas to check berfore i clean my AFM and pod.
P.s - ive been told that my ignition timing might need playing around. Could that be a possibility??
any help appreciated thanxx....
https://www.sau.com.au/forums/topic/161913-hesitation/
with a turbo tech boost controller you need them gapped at .08 - had the same trouble and misifre. but i think the controller i bought was stuffed , cause gapping fixed the misifire . although it kept dumping my boost when i go hard. so i pissed the controller off. my coil packs had not 1 crack either.
half of those turbo tech controllers were built stuffed . some with out a hole , some with . try another controller
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3006965
yeh mine came without the hole so i drilled 1 in there like every1 else was doing
i also had a greedy trust manual boost controller. still the same so im guessing
the problem is elswhere.
the turbotech i have isnt too bad i think. doesnt spike at all
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3006974
im in the proccess of changing spark plus and i noticed i have a split in one
of the black hose lines.
Not not to familiar what everthing is called but ill try 2 explain it.
its a U shaped hose roughly 15mm in diameter and goes over that black
rocker valley cover. directly in the middle.
any idea what im talking about or if that split hose could be causing hesitation
cheers guys.
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3007148
change your plugs completely
use ngk's still , but the part number is along the lines of r5671a - 8
might be a little too cold for your car , so get one thats one range hotter.
I've never heard of this R5671A-8... is it one of NGK's V Groove range of plugs? Whats the differences/advantages between this and the BCPR6ES that is normally recommended?
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3007231
hey guys well ive finised gappin my NGK BCRP7ES from .9mm to .8mm
i checked my coilpacks and i didnt seem to find any cracks.
i also pulled the rubber boot off and took the spring out and that copper bit seemed
to be fairly clean. Just took it for a quick drive and everything seems pretty good
Didnt feel any hesitation at all.
ill see how she goes in the next few days if shes still good and if she is well then
your plugs should be gapped at .8mm with the turbotech controller.
just another thing to keep in mind because it has worked for me for now.
Cheers for the help fellows.....
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3007671
yeah the 5671a-8's are a v groove , but theyre a non protruding plug.
if anyone can be bothered and has a dyno at there hands , spend the 20 bux on a set and see what improvements it will make , back to back against your old plugs.
other than that
as described above , check for the usual afm , fuel pressure or filter , air leaks , exhaust back pressure.
must admit i havent had a great deal to do with skylines , but vls do share very common problems with skylines
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3007914
cheers guys.
This will not cause the hesitation, I just found my hesitation problem, similar to your problem, it turned out to be a very dirty fuel filter, and i mean dirty, the fuel that came out of it was black! try it. part number z200
https://www.sau.com.au/forums/topic/161913-hesitation/#findComment-3010227
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
