hey guys recently bought an S14a and the guy gave me the dyno results, as you can see there is something crazy going on with the power curve. He said it was the coilpacks going, I know unichip is not the best but I dont think the unichip would do this. I dont have AFR, but he assures me they were fine (yes I think he was honest) and have recently upgraded to Bosch 040 and noticed no difference. Do you think its the coilpacks, I was thinking about buying some spitfire ones.
current mods are:
exhaust
FMIC
boost 0.8bar
unichip
Bosch 040
https://www.sau.com.au/forums/topic/161921-possible-ignition-problems/
Its either coilpacks or the ECU.
The ECU on SR's is nortorious for running rich as stink, so you really need an AFR graph.
Its not running factory boost levels, so im placing bets on the ECU. unichip really is a poor option.
I wouldnt purchase anything until you see the AFR's to be honest.
yeah, unichip is not my choice, I asked the seller and he assured me that AFR were fine, he wasnt the type of guy to stinge on that type of thing and it was also tuned by CRD, whom I thought would have some experiece in SR20s. Yeah I thought dyno was going to be the best option for me. I would have liked to have dynoed after problem was fixed.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
