they r good. period.
seriously...they tune cars well. one thing i learnt from them is that my spark plugs should not be .85 but 1mm or sumthing like that.
had them do my servicing three times n my car's running well. plus they installed all the mods n tuned my car. ask slip or abu53 how it goes.
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-332376
why cant we go into details? is this the case? could someone explain to me why? correct me if im wrong, but this is a discussion forum for discussions right? is it because a business name is involved? we talk about getting bad batches of fuel from shell, bp or whatever, and no one seems to mind. they are actual experiences and not something we whipped out of our arses. rb26 speaks highly, i speak highly, and im sure many speak highly of chapmans, but if the people who have had bad experiences, can't share their experiences isnt the story a little one sided? we may as well all be making statements instead of asking questions and having a DISCUSSION! so please, for those that have had a bad/good experience, PLEASE DISCUSS!
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-333682
rb26's car goes like a rocket, very smooth (except for the clutch)
Atomic, no no no. If we have ph and hungry6, part of SAU, posting on SAU forums saying negative things about a workshop, theres a whole lot of SAU in there. We do not want bad relations with workshops ESPECIALLY in this instance, where there are obviously a number of happy customers. We keep it in PM and email in this situation. You would be very unhappy if you were the workshop concerned, they probably have no idea about this thread, and therefore no chance to reply. If they did it would most likely get very messy if people less controlled than ph and hungry6 were involved. This has happened more than once in the past.
ph and hungry6 - thank you.
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-336115
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
