Well my drift car project is finally nearing a finish.
I am wanting to do the 2 tome with black above the window line and white all below
It does look quite aggressive with the kit being black though.
So we might have the black under the top of the side skirt line all the way around.
Colour change skills will be much appreciated.
;) Aaron
https://www.sau.com.au/forums/topic/162291-colour-change/
We taking bets on the time it takes to get defected?
The Slide plates are going on it.
To make it fair it will not be for reasons other then random pull over.
My bet is 2 weeks.
I also bet it will happen when i am in Sydney.
And yes Silvia came out with RB's *whistles
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3014263
No ?
Cry me a black and white river emo kid and paint the car lol
It will be painted this weekend coming black above the window lines and white below.
It will go well with the stickers that are the same that are being used on other sponsored cars.
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3035986
Ok now the bet is for how long it takes me to get James' keys when im in Sydney and to get his car on the hoon list :w00t:
My bet is 20 minutes and 5 seconds
key??? whats is this key you speak of?
you mean to say that I'm NOT allowed to drive other people's car by the exposed wire method??.....DAYUM!!!
:):D
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3037659
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
