Hey trooper ram it up ur ass lol
Carbon fibre is about $50 for fibreglassed board.. about 30x30cm .. unfibreglassed sheet is obviously less!
I was just saying what I thought and was looking for a reason to buy one .. but I just got a responce which didnt inform me of anything.. just why I should not comment haha
And to andru, im sure its top quality as it looks it .. But hey $300 is a fair wack of money concidering ebay sells 33 ones for $70-90 bux .. But it is C.F so I understand some what..
Might buy one .. But have to think bout it .. Cheers again
Edited by DECIM8
  • Replies 45
Posted Images
Please learn to spell and then come back to see me if you want conflict. "concidering" your intelligent "responce" I am sure that you do very well in school, and in fact should do very well when you get to year 12.
Haha its a "rip off" but you "might buy one". WELL DONE
lol fire up... apart from leaving skool ages ago i have no need to use correct spelling for this forum.. im sure you understood the convo minus the mistakes..
yes i feel its a rip, you may like to blow money each to own..
I'm pretty damn sure this wouldn't clear defects in NSW either. Unless you put sound deadening on the inside to block the noise of the pod.
Otherwise it's not going to pass any sound test.
The only advantage is that if you have one it may tend to look legal to an untrained police officer.
I've seen alot of dodgy carbon products but after seeing a lower lip that topstage did i think there quality is right up there with the best...
i think that style airbox really tidies up an engine bay, and if anyone was worried too much about heat i'm sure you can get them ceremic coated at an extra cost.. we do it up here with alot of our carbon products...
also your talking about wet & dry so is topstage now using pre-pregs?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
