Hi guys
Given the extensive coverage of this job on other skyline engines - Im wondering about this for the rb26, as I'm having a few minor idle hunting issues when under electrical load (headlights etc) and I heard that cleaning this valve may fix it - Can anyone shed some light as to where / how it is done ? Appreciate any advice in advance.
Thanks
Andrew
https://www.sau.com.au/forums/topic/162417-cleaning-aac-valve-in-rb26/
Thanks for the help boys, Ive had a look at the Rb25 write up, and even tried to follow it and find the valve in my engine bay, but it turns out theyre not the same - Ive also heard someone mention that the valve is under the manifold? Cowie, if you've got the wherabouts of anything on the RB26 i'd be grateful!
Thanks again
Andrew
have a feel under the manifold around the middle. You can feel the AAC assembly and i think the idle screw points towards the front of the car aswell
getting it off is another story and its even difficult to touch the bloody thing. Theres not even enough room to swing an ant. Id take the cooler pipes and battery out and place a mirror under the plenum to try and locate the screws to take the thing off. Good luck!
Failing that, id say the plenum would have to come off...yuck!!
intake.doc
Edited by SLIPPERY
Thanks Trav, that just about settles it :thumbsup:
The AAC can be easily removed without taking off the plenum, or sub plenum. It's bolted to the side of the sub plenum using 4 x 6mm bolts (10mm hex head) and these can be undone using small (1/4" drive or perhaps 3/8") ratchet. The bolts undo/come out toward the drivers side shock tower. It's actually more difficult to disconnect th short air hose connecting the AAC to the plenum as it's quite stiff and can be difficult to disconnect (or reconnect) in the confined space. There's also a gasket between the AAC body and the sub plenum which will almost certainly break or be damaged, so have a spare on hand.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
