I need help !
I'm changing my shocks and springs and need to know the standard ride height of a R33 GTS-t.
So if someone with standard suspension can mesure up their car from the centre of the wheel to the lip of the guard (front and back) it'd be great. And if you could just take not on how much fuel you have in the tank when you mesure it too....
I mesured up Shell car (thanks Shell :) ) but I just want to double check cause I've been told something different to what I messured :)
Shell's car got 365mm front and back with a full tank.
ATM mine mesures 355 at the back, and 335 front - but has coilovers, so it ain't stock :D
Thanks
Jayson
No probs Jay :P
if you need it for anything else, just give us a yell...
and just FYI, it was closer to half a tank than a full one (i had a qik look at the fuel guage when i drove off)...musta used more fuel than i thought...
Shell - you used that 1/2 a tank of doing burnouts I bet :)
Ken - thanks for that, so that's 376 front, and 363 rear.
I'm aiming for about 355 front and rear. The other car that was measured up was 375 rear and 365 front, so I think the rear springs tend to sag a little over time, or are pretty soft so are easily dropped depending on the fuel etc....
Thanks
Jayson
Jay, i will do it tomorrow for you. Just remember though, that even stockers are different; depends on the wheel/tyre combo. I'll post that too when i measure it
I have stock 16" rims, suspension and 205 tyres... cant remember the profile but will check it tomorrow.
OK, just measured it:
Ft: 355mm
Rr: 355mm
Half tank. No occupants :(
205/55 tyres. Stock suspension. Hope that helps.
Thanks for the replies everyone.
I've worked it all out and ordered the new springs.
After having a chat to NDR and to Jackie at whiteline (who sounds hot !!!) I figured out that the whiteline stage 1 springs drop the car to 345mm. The springs are 35mm lower springs. So that works out that the stock ride height is 380mm (we're talking about NEW stock springs here :) ).
I only want to drop it 25mm, so I had to go the KMAC's cause whiteline only have 35mm+ ;)
Jayson
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
