HIya, does anyone know the details of the crowd in Wandi that do ceramic heat coatings?
GTST-VSpec has told me their name in Competition Coatings, but they arent in the whitepages so if anyone has their phone number it would be appreciated - trying to organise my dump pipe coating for tomorrow.
Ta
Conrad
https://www.sau.com.au/forums/topic/16264-ceramic-coating-in-wa/
This is the contact for the Ceramic Coating place in Wandi. Have just sent off manifolds and turbine housings and will be sending off dump and front pipes very soon.
Lyndon
telephone: 0500 8999 88
address:
3/29 Blackboy Grove
Wandi WA 6167
Australia
Cheers
Brendan
Just thought I'd post up for future honkeys looking for the info. Dunno what it looks like yet, think it only went off on Friday with a bunch of other stuff from C-Red. Turn around time is a minimum of 3 days and the very hi temp stuff (think it's branded their 'Platinum Coating') is being used on the stuff I mentioned - so only a black satin finish is available.
Cheers
Brendan
Yeah, that's the same stuff that we got done.
Adam, Yes he's thinking about doing a RWD conversion later. The owner, Ray and other are working on the car, it's easier to say "we" rather than go through the details, then people can ask me if they want more info.
Slightly off post but related, I plan to get the inlet manifold on my "R" coated.
The PFC allows for monitoring of the air inlet temp and this suffers badly from heat soak when not moving. It takes a long time for the temps to drop again once you start moving. I confirmed by finding the manifold very hot to the touch (estimate ~ 70 C) when the air inlet temp temp is showing around 50 C.
The intercooler outlet pipe actually stays very near ambient temperature (from constant checking by touch) with only minimal driving, however, indicating that the intercooler is working quite efficiently.
It would therefore seem that with a decent intercooler, controlling heat soak from the inlet manifold is just as important (or more so) than having a cold air intake box.
Comments?
Hmmm, interesting thoughts. I suppose the other thing to look at would be where is the heat being generated from to make the plenum warm in the first place. Most I suggest, would come from the block, but certainly some woiuld come from the ambient hot air coming from the turbo side of things? I supppose the coating of the plenum would certainly help. Approximate cost would prolly be in the vicinity of say $60-90 (guestimate).
Cheers
Brendan
Yep
that's my point - almost certainly radiant heat from the block.
I'll probably try placing one of the Jaycar temp probes in different positions between the IC and the inlet manifold to confirm - Oh no, I'm starting to feel a bit like Julian Edgar now!
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
