Hi guys hope you can help.The air cond in my 32 gtr is playing up it has started blowing hot air i mean f**king hot and when you turn it off while driving hot air still comes through the vents. also idles like shit when i turn the air on.
thanks CHRIS.
https://www.sau.com.au/forums/topic/162699-air-con-problems/
This usually means the cabin temp sensor has failed or been disconnected or the climate control computer is broken.
Check the sensor located behind the gear stick surround make sure it is plugged in. If it is, try cleaning any dust or othe garbage off it.
There is an aircon diagnostic you can perform , do a search for the instructions.
ร—
ร—
