Hi all
I have a strange whistle/Squeak at idle in my car. It is constant, and as soon as i blimp the throttle it disapears. Only occrs after the car has warmed up. I have all new gaskets and studs exhaust side.
It is hard to see where the noise is coming from, and as you turn the car off, it dies down with the engine.
No recently i cleaned my TB, and Cold start valve, and have since look at these again, but i cant find any issues with these. The engine hasn't lost Vaccuume, and still dirves fine.
Is it possible that it is a whistle from the TB or something similar.
https://www.sau.com.au/forums/topic/162821-whistlingsqueaking-at-idle/
i have the exact same problem = and the same symptoms . the it is really hard to diagnose where it is comming from . sounded like any air leak at 1st, but then it changes tone a bit . my car has been sitting for a few months with out more than a 100 meter drive which iv done like once ever few weeks.....
if i knew where it could be from id be looking for ways to fix , iv just given up.
i have the same squeek at idle goes away while driving..... not sure if its the belts or what.... sounds real dodgy when idleing and gets louder when its hot and been driven for a while.....could it be the cooling fan bearings?
  • 2 months later...
Check all three belt tensions first - make sure they are not loose.
I suspect the sound is coming from the bearings on the air con compressor pully - the one on the compressor - not the tensioner pulley.
I had a noise I couldn't identify - I just got a new water pump fitted so it wasnt the issue.
So I took off the power steering pump belt and the noise was still there.
Then I took of the aircon belt and presto - the noise was gone!!
I rotated the pulley on the air con compressor by hand and it was extremely noisey - you could feel the "roughness" when rotating the pully.
Try it yourself and see.
The CAS noise sounds like a rerw rew rew rew rew.
The air con pulley noise is more like a metal squealing or squeaking - and is constant. Not pulsing like the rerw rerw rerw of the CAS
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
