The Grant/Grant Sizzler car from 1990/91/91 has been found alive and well in New Zealand.
It has been bought and should be arriving back in Australia around the end of this month.
The new owner is keen to have it racing at the Oran Park historics on June 1/2/3 where it will join Rod Markland, and Terry Ashwood's Gibson Motorsport HR31's.
It was originally Marks Skaifes 1990 car (chassis #4) but went to Alf Grant racing for the 1990 Bathurst in Sizzler colours.
It was raced on and off over the next 2 years including Bathurst 1991 were it finished 5th outright, with its final outing being Bathurst 1992 were it finished 12th outright.
Another classic Nissan racer back from the grave.
Hooks
https://www.sau.com.au/forums/topic/162915-sizzler-hr31-returns-to-oz/
  • Replies 90
Posted Images
and here it is
thanks to dave31gtsr for the image
3 gibbo coupe's racing @ once!!!!!
boys if you come out to oran park make sure you go up and say hello to rod or terry. it is gonna be awesome.
31GUN or mark will give you the grand tour of the car
he's not hard to miss
hope to see you guys out there
cheers, MARK
couldn't agree more troy
i must say the gibson hr31s dominate their particular race
not sure what hooksy's view is, but Peter Brock's departure last year was a disappointment, in the fact that he had got back into the Historics with a Torana.
he was pushing Terry and Rod to their limits.
but anyway, 4 would be fantastic.
to a 31 loser like me, it's god's cum.
anyway see how we go
troy i will be coming down for any victorian rounds
would be great to catch up for a beer mate
cheers, MARK
yup
poofters
tell ya what, and you're a sierra fan roy, there used to be a sierra racing at the historics at a coupole of eastern creek rounds
poor old nissans struggled to keep up
we need that guy back to keep rod and terry on their toes!
Is that the B&H car? Yeh an ANZ car landed back in the country last year with the intention of also running. There is also the PJ Sierra down here in Vic, but there is no intention to run that car.
Rewind 12 years, if i could pick up a chassis for the same money they were going for back when 2L died and you could get your hand on the M3s, Ellery's converted Sierra etc real cheap. Or hell all those VLs! But they are all big money now, and it looks like the HRT VL will be keeping the Nissan guys honest.
Be interesting if Jim lands a drive that he is chasing...
Grapevine says PJ Sierra is coming back out to play later this year.
Grapevine also says that Vic R31 IS ready, and has been for some time.
Driver got cold feet? Small testicles? Handbag?
:thumbsup:
Hooks
Which PJ car? There are two to the best of my knowledge. I have met one of the owners as his brother has a very quick R33 GTR that you see around the traps at trackdays. They also did the 2005 Vic Dutton together in the GTR. The other was for sale last i heard.
LOL..as for the Vic R31, its not cold feet, nothing to do with testicle size or women's accessories :) When the owner and car are ready im sure it will be out there. He builds some beautiful cars, its beyond me how he can turn around and go race them ;)
Hehe, the GIO car was at PI on the weekend. My R32 GTSt was quicker the week before :) Its such a great looking car. I understand 100% why the owner may not want to push the thing. Either way it looked great out there and hats off to Gavin for putting it on the track.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
