The amount of ignition you can push in really depends on mods.
For a dead stock R33 it may be possible to push in 4-5degree's on BP98, one running 12psi it may not be.
Which is why its so important to do it on a dyno.
As for checking for ping. I found the best way for myself was in third and fourth up against a guard rail. Its still difficult to hear so be very very carefull. The stock ecu only provides 'some' protection under 4500rpm, over that and it will allow you to detonate the motor to death.
Varying conditions also can induce ping that was not otherwise present. Give it a really icy night and it may very well ping where it wasn't on the usual 25degree day.
Ok so I've the regular bolt ons, exhaust, pod, fmic, 10-12psi. Does that mean I can't push the timing as far?
For the sake of a trying to get another 5rwkw throw it on the dyno to be sure all is ok when pushing up the ign. timing.
Its not worth a 3-5k rebuild.
I see your point. Dyno's aren't cheap around my area ($100 for a power run). Better safe than sorry.
So even advancing it say 2-3 degree's is not a good idea to do at home?
well, the thing is, 2-3 degrees might very well not be. If for some reason, you have a high compression motor (e.g. an N/A) motor, it will probably ping. Or if you have bad fuel etc etc.
It's just really hard to listen for ping while you're driving the thing. On the dyno, they can listen out for it, while standing next to the car with the bonnet open - can't do that while driving :happy:
If you run something like shell v power racing, you can probably knock a fair bit of timing in. It'll have more power, more torque, quicker spool, better response.
People normally increase it till it pings slightly, then back it off a little.
I forgot where, but htere was a place that had dynos for $80 an hour.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
