I had mine checked out at all about gearboxes at girraween.After the crash I didn't know if there was any damage to the box so took it there and had it checked,he welded up a small crackin the rear housing checked the gears and syncroses and bearing's said all was fine cost me $250
Cheers Peter
PS web site. www.allaboutgearboxes.com
did u forget to use the clutch when changing gears again? bad smokeh!!
Is that what its for?? :wave: I thought it was another foot rest for my right foot?? :laugh:
Take it down to Greg at Autosport Engineering in Kirrawee for diagnosis.
Thanks Adam and Risking.. I called up Autosport Engineering yesterday afternoon and Ill be booking it it sometime late next week to get it checked out.. Ive heard good things about Autosport Engineering in the past.. I didnt realise that the did gearboxes as well.. it sounds like the one stop mechanical workshop!! ;)
Learn how to change gears?
:Oh snap beyotch:
Im sorry.. are you still speaking *hands Steve-o toilet paper to wipe the bullsh!t coming out of his mouth!!* :wave:
Cheers Peter
Thanks for the recommendation Peter :laugh: the thing is Giraween is abit out of the way for me.. Im going to go with Autosport Engineering as they are also conveniently located..
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
