Yeah needle nosed pliers and squeeze and gently push on them and they should pop out one at a time, really fiddly the first time you do it, but once you've done it once the next time it'll be a piece of piss!
hey hugh hurry up & do it then post a pic & dont forget to get a shot of your roofracks to show the crew.
ps & and dont break anything.
Hey Leigh I need some serious help to get my Stag upto speed.
Got the grille out. Well not me, my wrist strength is still not up to speed after the recon.
A mate came over and did it for me.
It's not what you know, it's WHO you know that really counts.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
