Hey Guys
I recently installed a HKS mushroom filter on my S1 R33 (Auto) and noticed that the idle is running rough. Sounds almost like its missing a bit and revs at idle range from 400-900. The power on low end (10-40km) is really shite as well, feels really laggy. This is the only mod i've done to the car, everything else is bone stock.
The air filter was put on after a mate tried to get more sound out of the stock BOV. I.e. Plugged the plumb back hose and vented the BOV to atmosphere. We found that the car ran rough as guts, hunting at idle and stalling, but sounded great hahaha, so we put the BOV back to stock plumb back and just bolted on a mushroom filter. Later did some research and heard that stock BOV is always open just a little and idle was hunting due to lack of back pressure. Is this true?
My assumption is that the problem will be fixed after installing an after market BOV which stays closed when not venting. Will this fix the problem? Also I haven't reset the ECU after changing to mushroom filter, maybe give that a go????
Cheers
https://www.sau.com.au/forums/topic/163542-rough-idle-after-pod-install/
How do you clean your afm?? Carby cleaner yeah but like do i open it up and spray in there? I would have thought this problem had more to do with air pressure?? Wouldn't know SFA though so any suggestions are welcome. Thanks for the replys so far guys
an aftermarket bov won't allow you to have it atmospheric because vacuum will still be strong enough to open it under normal driving conditions unless you tighten the bov more but then there is no point having a bov if it's too tight to properly vent pressure and cause flutter.
when your car is using an AFM its best to keep the bov plumbed back to the intake even if it's aftermarket because you're letting air that the AFM has sensed and added fuel for out of the system causing richness.
to put it simply every time you hear the bov vent you would be wasting fuel and your car would not run well.
Air Flow Meter!!! NOT Air Pressure Gauge..........
Who said Air Pressure Guage?? Can't find it anywhere on the page....
So Dobz..Are you saying that i can't have an atmospheric BOV??? How do other skyline owners do it? Plus i thought you have to have some sort of AFM all the time??? Confused.....
you can have an atmo BOV , you just need a good one which has a good spring and vents well . yes a lot of people have idle troubles because of them if not setup properly . try adjusting the bov , and watch your idle change . a cheap bov will cause numerous amounts of trouble because they arent made well - hopefully you have a decent one , for your own benifit.
here are some things to do :
ACC Valve : search ! . you will find a very well written DIY to clean everything out . your idle will run much better . you need carby cleaner for this - its a must !
AFM: clean it with carby cleaner aswell , spray it in the direction of the arrow on the AFM. there could be some debree attatched to it .
both of these will definitly help your idle if not fix it . remember to search before you post.
its most probably due to the bov not being plumbed back as the ecu is expecting that extra air being recirculated, i did the same of my gtst and it ran like crap plumbed it back and it was all good and because i had a pod put on you could still hear the bov pretty loud if thats what ur after. However i seen ppl not run plumb back systems and they ran fine, you can get a extra module to control ur idle etc, ive also seen ppl run two bovs, the original plumbed back and another one to the atmosphere which works too i guess.
The BOV is still plumbed back, changed that back to stock before adding the pod. I noticed last night that it behaves much better at night when the air is cooler than in the day, might sound stupid but it seemed heaps quicker than when stock. It's just in the day time that its really laggy from 0-40km/h.
Maybe the super special microchip in the pod is dirty. Try cleaning it and it will not only run better but give you 20 or 30more rwkw's . :laughing-smiley-014:
but in all seriousnes just try disconnecting the air flow meter and putting it back in again, also reset the ecu before starting car again. I ave had identical problem twice after mucking around with the pod filter and thats what fixed it for me..
good luck
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
