plenum heatsoak excessive
I doubt the intake air is hanging around long enough to extract any heat from the plenum.
If it passes through a hot space the air temperature will rise..but like elk was saying it only gets sucked in when the throttle body is open, so its probably not enough to cause massive heat soak.
Have u wrapped all the piping from the exit side of the intercooler to the actual plenum? I need to do that to mine, as i get pinging after high temps, even though my FMIC is quite large. As the cool air from the i/c passes back across near the engine, it can start to heat up again. Other solution is custom plenum which takes the intake direct from the front without crossing over the engine.. if u want to spend the money.
Guest INASNT
Originally posted by Sydneykid
Hi Guys, the air speed throught the plenum is too high for any heat transfer to occur.
yes as skydneykid said the air would have to be moving real slow for there to be time for heat transfer to occur between the air and the pipework/engine heat!
Sydneykid - according to the PFC in my GTR, the air temp is a lot higher (at times up to 60 C) when the IC outlet is cool to touch.
One possibility is that sender may actually be heating up by conduction from the manifold. How far does the temp probe go into the air stream?
Guest Boxhead
drift me silly is at my place atm, and wants to say the following =
the air moving quickly theory makes logical sense as does the exit intercooler to throttle body wrap, does anybody know if there is any drop in plenum temperature if a vented bonet is applied? and if so, how much?
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
