Ignition Hotspots Cruise #3 Dvd Video Shoot - Friday 13th April
It's that time again guys! The Ignition Crew are back down in Adelaide and are looking to make some footage, so get out your hotest rides and roll down to get them featured! (or even to just take part in the cruise that follows)
As always, a big warm welcome to all SAU members who want to come to this, we are looking forward to having your cars here too!
where: northgate shopping centre
corner of fosters road and folland avenue (northgate)
near hampsted road / grand junction road / north east road
when: 830pm Friday 13th April
Itinerary: 1-2 hours filming & featuring cars, followed
by a cruise that combines the best of hills and streets
Edited by loz-SC400
This should be good, we need more cars going to this one. I have an Adelaide hotspots on an ignition DVD from a while ago and they kinda dissed us, we need to show them that we got plenty of nice rides down here in Adelaide and we ain't that boring after all!
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
