Item: Pioneer in dash TV/DVD/MP3
Website: http://www.pioneer.com.au/products/c...DVD/index.html
http://www.pioneer.com.au/products/c...TVP/index.html
Item Condition: Great had it im my car old n14 for around 6 months
Reason for selling: Dont use it anymore and need cash
Price and price conditions: $1200ono+ postage if required
Extra Info: Includes the Tv tuner worth $999 alone making the total value well over 3k all you need is the tv areals 2 plug in and your set.
Pictures:
Edited by RUF32R
The specs are;
IN-DASH 6.5" TOUCH PANEL
DVD/VCD/CD SCREEN
· Dual Zone Facility
· Hideaway Module
· Touch Screen Operation
· MOSFET 50 watts x 4 High Power
· PAL and NTSC compatible
PRODUCT DESCRIPTION
In-dash Motorised 16.5cm Screen with Integrated DVD Player, AM/FM Tuner and High Power Output, Dual Motor Drive for superior operation and rigidity, Detachable Face Panel with Theft-deterrent LED, IR Remote Control supplied, Dual Zone Facility (F=Tuner/MCD, R-DVD), 10-character Sub Display when screen closed, Hideaway Module (1.5m cable): 150 x 28 x 100mm
LCD MONITOR
Touch Screen operation, Anti-reflective and Fingerprint resistant screen coating, Rear View Camera Input (camera not supplied), Auto Switching to Rear View when reverse gear selected, 5 Viewing Modes (Widescreen, 3:4, etc.), Adjustable Screen Position with Memory, Set Back screen, 2-position selectable, TFT (Thin Film Transistor) Display, PAL and NTSC compatible, On-screen Setting Menu, OSD, Auto Dimmer Control
SUPERTUNER FEATURES
Supertuner IIID with Digital Processing, Provision for upgrade to DAB, Selectable Local/DX/Local Seek, 9kHz/10kHz switching
PLAYER FEATURES
DVD for Region 4 and "Open" Discs, Compatible with CD, CD-R, CD-RW, VCD, DVD, DVD-R, DVD-RW, Suitable for Double-sided and Dual-layer Discs, Search by Title, Chapter, Time, Direct Playback for 8cm Discs, Built-in MPEG 2/1 Decoder, MP3 Playback with ID3 Tag
SYSTEM CONNECTION
Optical Output for Dolby Digital and dts 5.1 audio, PCM Linear Stereo Audio Output, RCA Input (L+R+Video), RCA Video Input for Rear View Camera, RCA Output for Rear Screen (L=R=Video), AV Bus Input for GEX-P6450TVP TV Tuner, Pioneer P-Bus Input, Multiplay CD Control
AUDIO FEATURES
MOSFET 50 Watts x 4 High Power, Rotary Volume Control, EEQ+ (Easy Equaliser), EQ-EX (Augments EEQ+), Dual + Sub 4-Volt RCA Preout, 2-way Crossover: 50/80/125Hz, Direct Subwoofer Drive, SFEQ (Sound Focus Equaliser), Digital Listening Position Selector (LPS), SLA (Source Level
Seeing as ur in need of cash, PM me with the $ you want for the dvd player without the tv unit.
I can pay today, depending on how much you want.
Please include postage to Mildura, Vic with your price (I'm not one for haggling, so I'll either take it or won't).
Thanks.
Thanks.
PM sent
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
