ok i have searched far and wide and i cannot get anything!!!! 4 different forums and many traders haha.... apparently they make no more for rb20! soooo what can i use as a replacement?? please help and i dont wanna remap my comp everytime i modify!
cheers
https://www.sau.com.au/forums/topic/163810-pfc/
  • Replies 48
I'm still a big PFC fan... The knock dash light flash is awesome, confidence inspiring especially as dyno's have a nasty habit of not placing enough load on the motor during tuning, once u get it on the street and load it up in that 4th gear from low rpm it pings its arse off. :w00t:
https://www.sau.com.au/forums/topic/163810-pfc/#findComment-3037681
A lot of tuners have a bad taste in their mouth when they hear the word Greedy Emanage.
As a result some will steer you away from it.
As with everything.. Some tuners deal microtech, some autronic, some microtech + powerfc. Use the ecu your tuner feels the most comfortable with as you WILL receive the best tune doing so.
Paul.. 440 is for a full tune.
https://www.sau.com.au/forums/topic/163810-pfc/#findComment-3040951
i dont get it, why the bad taste. is it because no ones had experience with it or bothered using it?
Cubes can you provide a few good reasons why Greddy Emanage isnt used apart from tuners being lazy?
Thanks.
A bad taste is where in the products history it has performed Poorly. Hence the bad taste left over from the older greedy emanage version.
Apparently the Emanage Ultimate is better. But the damage has been done. Its left a bad taste.
Absolutely nothing to do with slackness.
URAS has good results with them. Get him to tune it.
Go to some one who doesn't know its in's and outs and you are likely to not get a nice tune without spending big $$ for dyno time and fiddling around. Quite obvious really.
Now that the PFC is out of the picture it may very well take off, the tuners will be forced to spend some time on the greedy as they become more common.
https://www.sau.com.au/forums/topic/163810-pfc/#findComment-3042238
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
