hey guys
selling these:
BODY:
r32 door mirror's-
r32 2dr drivers door-
r32 2dr passenger door-
r32 REAR reo bar -$130
r32 type-m rear bar -$100
r32 type-m passenger side skirt-$75
r32 shell- 1k
DRIVELINE:
r32 gtr/gts4 driveshaft -$150
r32 gtr/gts4 tailshaft - SOLD
A pair of R32 GTR/GTS4 6 bolter rear 31spline 6bolt Axle's - $150
SUSPENSION & BRAKES:
R32 GTR front caliper's- offers
r32 type-m rear calipers-offers
full set of r32 GTST M-spec rotors- offers
r32 rear 5 stud hubs with LCA-offers
r32 tein fronts gts4/gtr -
r32 koni rear 2 point height adjustible shocks gts4/gtr-
rear r32 2dr handbrake lines-
LIGHTS
r32 type-m fog lights (pair)-
passenger side headlight-$70 ( comes with most of the wiring)
WHEELS
16" 5 stud dishies 8" wide-offers
OTHER
r32 gts4/gtr/gts/gtst ABS unit -offers
interior parts:
r32 2dr rear trim under 1/4 window -$150 both for lhs+rhs
RHS r32 2dr 1/4 window surround- $50 SOLD
rear view mirror-
r32 1993 spec rear seats-$200
r32 gtst steering wheel- ok conditon $100
r32 interior goodies- mostly perfect condition ~take wat u need~ - make an offer
let me no
in melb
i might hav sum more so let me no wat u need
Edited by Dan_J
https://www.sau.com.au/forums/topic/164334-delete/
blinko : think i got it, you mean da left kick panel on da drivers side?
wannabeslida : yea i'll pm da price and price for postage soon
LoNg_ShaNks: no aircon vents only heater vents
ducki: sorri no rad
Edited by Dan_J
https://www.sau.com.au/forums/topic/164334-delete/#findComment-3047497
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
